Zum Hauptinhalt wechseln
Speziell für diesen Teardown benötigte Werkzeuge
Einleitung
Teardown of Car and Driver Auto HandHeld Vacuum Bagless. Portable Vacuum .
Dieser Teardown ist keine Reparaturanleitung. Um dein Car and Drivers Auto HandHeld Vacuum Bagless zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Locate the  four screws locate outer gray shelll ''I REMOVED THE SCREWS WITH PH #OO SCREWDRIVER FROM (IFIXIT) New PLace  four screws to the side
    • Locate the four screws locate outer gray shelll
    • ''I REMOVED THE SCREWS WITH PH #OO SCREWDRIVER FROM (IFIXIT)
    • New PLace four screws to the side
  2. Here are the four screws from vacuum
    • Here are the four screws from vacuum
  3. Remove the top grey shell of the vacuum Place a red tab to the side Let start looking at the 9volt motor with wire and on/off switch.
    • Remove the top grey shell of the vacuum
    • Place a red tab to the side
    • Let start looking at the 9volt motor with wire and on/off switch.
    • I remove the outer shell . I remove the motor and wires and on/off switch.
  4. This it complete teardown on Car and Driver HandHeld Vacuum bagless!
    • This it complete teardown on Car and Driver HandHeld Vacuum bagless!
kempc8
899 Reputation
7 Anleitungen geschrieben
K and K Fixit Mitglied von K and K Fixit
Business
1 Mitglied
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 7
Insgesamt: 801
