Zum Hauptinhalt wechseln
Dieser Teardown ist keine Reparaturanleitung. Um dein Clevo Sager Eurocom P650RG G zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Clevo Sager Eurocom P650RG G Teardown, Clevo Sager Eurocom P650RG G Teardown: Schritt 1, Bild 1 von 1
    • Not a full teardown; just board photos (both sides) and things that I couldn't find on the Internet easily.
  2. Clevo Sager Eurocom P650RG G Teardown: Schritt 2, Bild 1 von 1
    • Internal battery, 60Wh
  3. Clevo Sager Eurocom P650RG G Teardown: Schritt 3, Bild 1 von 2 Clevo Sager Eurocom P650RG G Teardown: Schritt 3, Bild 2 von 2
    • Top assembly. Screen is attached to top case.
    • The two 2W speakers are quite large and sound fairly nice, surprisingly. Doesn't look like they're ported enclosures.
  4. Clevo Sager Eurocom P650RG G Teardown: Schritt 4, Bild 1 von 1
    • The copper heatsink is screwed onto the bottom cover. The CPU fan draws air through this area (not a lot though).
    • Copper heatsink with heat pads for the CPU and GPU voltage regulator MOSFET/inductors. During reassembly, make sure no wires cover the MOSFETs
  5. Clevo Sager Eurocom P650RG G Teardown: Schritt 5, Bild 1 von 3 Clevo Sager Eurocom P650RG G Teardown: Schritt 5, Bild 2 von 3 Clevo Sager Eurocom P650RG G Teardown: Schritt 5, Bild 3 von 3
    • Board Photos bottom side
  6. Clevo Sager Eurocom P650RG G Teardown: Schritt 6, Bild 1 von 3 Clevo Sager Eurocom P650RG G Teardown: Schritt 6, Bild 2 von 3 Clevo Sager Eurocom P650RG G Teardown: Schritt 6, Bild 3 von 3
    • Intel Core i7-6820HQ, DDR4 RAM, GTX980M can be seen here.
Larry Chen
913 Reputation
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 60
Insgesamt: 5,114
