Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Commodore 1341 Joystick zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Commodore 1341 Joystick Teardown, Commodore 1341 Joystick Teardown: Schritt 1, Bild 1 von 1
    • Introduced in 1984, the Commodore 1341 joystick was designed for use with the Commodore range of computers including the Commodore 64, 128, VIC20 and Commodore Plus4.
    • This joystick connects to the retro computers using a 9 pin connection.
  2. Commodore 1341 Joystick Teardown: Schritt 2, Bild 1 von 3 Commodore 1341 Joystick Teardown: Schritt 2, Bild 2 von 3 Commodore 1341 Joystick Teardown: Schritt 2, Bild 3 von 3
    • The joystick is held together by five phillips head screws. One screw is located on the handle and the remaining four are under the base.
    • Once the screws have been removed you can pry the case apart using a flat head screw driver. Just be careful with the base as it is spring loaded and it can fly apart quite easily.
  3. Commodore 1341 Joystick Teardown: Schritt 3, Bild 1 von 3 Commodore 1341 Joystick Teardown: Schritt 3, Bild 2 von 3 Commodore 1341 Joystick Teardown: Schritt 3, Bild 3 von 3
    • You will need to desolder the fire button cables from the board.
    • Pry the case open but watch for the spring. There is also a rubber bung that sits beneath the black rocker shaft.
    • Desolder the cables from the main joystick board and remove all of the components.
    • Now you are ready to clean all of the joystick components and reassemble.
Andy Marsh
118 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 7,202
