Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein MP3 Player zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Cowon iAudio 7 8GB Teardown, Cowon iAudio 7 8GB Teardown: Schritt 1, Bild 1 von 1
    • The device in original condition.
  2. Cowon iAudio 7 8GB Teardown: Schritt 2, Bild 1 von 1
    • Removed the back of the case and the PCB screws. I had to drill open one of the case screws as it was stuck.
  3. Cowon iAudio 7 8GB Teardown: Schritt 3, Bild 1 von 2 Cowon iAudio 7 8GB Teardown: Schritt 3, Bild 2 von 2
    • All parts disassembled. Second photo shows back side of the PCB.
    • As we can see, the device contains two Samsung 4GB flash chips along with a K4M28163PH-BG75 memory controller.
    • A Telechips TCC771L as main CPU.
    • A PCF50606HN battery/power management chip.
[deleted]
210 Reputation
1 Anleitung geschrieben
3 Kommentare
2011music my songs
Tong Thao - Antwort
Hi! Could you, please, say what the type of display is there?
tikhonte - Antwort
If anybody needs a new battery, try this: 3.7V polymer lithium battery 503060 or 053060
The number means the dimensions (5 x 30 x 60mm) The first number is often in 1/10mm
You’d need to solder the original cable to the battery or cables though.
Maybe you want to leave a comment here if this was helpful: adahnsplace.blogspot.com
Endre Sutus - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 4,355
