Zum Hauptinhalt wechseln
Was du brauchst
Angehängtes Dokument
Dieser Teardown ist keine Reparaturanleitung. Um dein CucinaPro Cordless Crepe Maker zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. CucinaPro Cordless Crepe Maker Teardown, CucinaPro Cordless Crepe Maker Teardown: Schritt 1, Bild 1 von 1
    • The CucinaPro crepe maker has two main components: a heating body and a power base.
    • Disconnect the power base from the heating body to prevent undesired heating. Also disconnect from power so you don't die!
  2. CucinaPro Cordless Crepe Maker Teardown: Schritt 2, Bild 1 von 2 CucinaPro Cordless Crepe Maker Teardown: Schritt 2, Bild 2 von 2
    • Flip over the heating body of the crepe maker to access bottom screws.
    • Use a #1 Phillips screwdriver to unscrew 7 #1-20 x11mm and 1 #1-20x7mm screws along the bottom of the heating pan and the handle.
  3. CucinaPro Cordless Crepe Maker Teardown: Schritt 3, Bild 1 von 2 CucinaPro Cordless Crepe Maker Teardown: Schritt 3, Bild 2 von 2
    • Lift dipping pan from the plastic casing.
    • Dipping pan connects to plastic casing with nondetachable wiring.
    • The two wires connected to the black connector transfer the AC power from the base to the heating coil underneath the pan surface.
    • White sleeves surround the wires, protecting them from heat damage.
    • The black connector also holds a grounding strip not connected to a wire.
    • Used crepe makers will probably look as dirty as this. Unless you are the cleanest person to ever exist.
  4. CucinaPro Cordless Crepe Maker Teardown: Schritt 4, Bild 1 von 3 CucinaPro Cordless Crepe Maker Teardown: Schritt 4, Bild 2 von 3 CucinaPro Cordless Crepe Maker Teardown: Schritt 4, Bild 3 von 3
    • Unscrew 3 #1-20x10mm screws connecting the top of the handle to reveal the inside of the handle, switch wiring, and yellow tab covering the LED.
    • When the switch is open, the flow of electricity is interrupted and no heating occurs
  5. CucinaPro Cordless Crepe Maker Teardown: Schritt 5, Bild 1 von 1
    • Underneath the heating element are 4 black stands that provide stability by ensuring space between the bottom of the pan and the dipping plate.
  6. CucinaPro Cordless Crepe Maker Teardown: Schritt 6, Bild 1 von 2 CucinaPro Cordless Crepe Maker Teardown: Schritt 6, Bild 2 von 2
    • Unscrew #1-20x6mm screw on black temperature sensor to reveal a gooey substance between sensor and the metal undercoating of the heating surface
    • While the coil heats and the heating surface is below optimal cooking temperature, power enters the coil and turns on the LED.
    • Upon reaching the optimal temperature, the power to the coil shuts off and the LED turns off, indicating the crepe is done.
  7. CucinaPro Cordless Crepe Maker Teardown: Schritt 7, Bild 1 von 2 CucinaPro Cordless Crepe Maker Teardown: Schritt 7, Bild 2 von 2
    • Unscrew 3 #1-20x10mm screws from the bottom of the power base and separate 2 base pieces and a connector piece.
    • Connector piece allows electrical power flow from the wall socket to the heating body.
    • Also spy a model number on the bottom.
  8. CucinaPro Cordless Crepe Maker Teardown, Final Thoughts: Schritt 8, Bild 1 von 1
    • CucinaPro Cordless Crepe Maker earns a 8 out of 10 on our repairability scale (10 is the easiest to repair).
    • The Crepe Maker is easy to use and handle; the overall system is relatively light.
    • Temperature sensor made it easy to know when the crepe was done cooking.
    • Dipping plate was an effective way to put crepe batter on plate.
    • It is easy for batter to get in between the crevices of the device.
    • There is no easy way to clean the device.
    • Surface area of the dipping plate is relatively small.
Angehängte Dokumente
Cal Poly, Team 4-6, Maness Fall 2015 Mitglied von Cal Poly, Team 4-6, Maness Fall 2015
CPSU-MANESS-F15S4G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 986
