Einleitung
Tearing down a Cyclops Helios headlamp. Both hardware identification and functionality for the device are discussed.
Power off Cyclops Helios before tearing down by pushing the black button until the LEDs no longer emit visible light.
Black button - circled in red
Using two hands, carefully separate the front panel and back panel of the Cyclops Helios.
Front panel - boxed in red
Back panel - boxed in blue
Use a Phillips head screwdriver to remove two screws from the front panel.
The two screws fasten the outer enclosure with the inner electronics of the front panel.
Within the enclosure of the front panel there is a clear plastic lens, and plastic button insert. Both are removable.
Clear plastic lens - boxed in red
Plastic button insert - circled in blue
The inner electronics of module of the front panel includes a parabolic mirror, circuit board, and battery holder.
Circuit board - boxed in blue
Parabolic mirror - boxed in red
Battery holder - boxed in green
Separate the circuit board from the battery holder by desoldering the black and red wires from the battery holder.
