Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Datatronics Discovery 2400CM zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Datatronics Discovery 2400CM Teardown, remove front cover: Schritt 1, Bild 1 von 3 Datatronics Discovery 2400CM Teardown, remove front cover: Schritt 1, Bild 2 von 3 Datatronics Discovery 2400CM Teardown, remove front cover: Schritt 1, Bild 3 von 3
    • The front is attached to the body with 2 latches.
    • Using the spudger, open a latch on one side.
    • Open the latch on the other side next to detach the front.
  2. Datatronics Discovery 2400CM Teardown, remove back cover: Schritt 2, Bild 1 von 2 Datatronics Discovery 2400CM Teardown, remove back cover: Schritt 2, Bild 2 von 2
    • The back cover is attached to the body the same way as the front.
    • Open both latches to detach to back cover.
  3. Datatronics Discovery 2400CM Teardown, remove board from housing: Schritt 3, Bild 1 von 3 Datatronics Discovery 2400CM Teardown, remove board from housing: Schritt 3, Bild 2 von 3 Datatronics Discovery 2400CM Teardown, remove board from housing: Schritt 3, Bild 3 von 3
    • The board is attached to the body with 2 screws. The screws are hidden under "warranty voidance" stickers.
    • Remove the stickers so you can unscrew the screws.
    • Slide the board from the body.
  4. Datatronics Discovery 2400CM Teardown, overview: Schritt 4, Bild 1 von 3 Datatronics Discovery 2400CM Teardown, overview: Schritt 4, Bild 2 von 3 Datatronics Discovery 2400CM Teardown, overview: Schritt 4, Bild 3 von 3
    • Overview of the front and back of the board, as well as a detailed view of the label.
knipwim
8.527 Reputation
30 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 900
