Was du brauchst
MP60
6ft Heavy Gauge Line Cable
6ft Ethernet Cable
Wall mounting screws
8x 3mm Triangle bit case screws
9x Philips #1 Screws
User resettable 16a breaker
10/100 Ethernet
Assembly lifts out as a single piece after removing screws
The wifi board and antennas are located as far away as possible from the power supply to avoid interference.
Qualcomm - QCA9531
560 Mhz CPU (Not too shabby for some outlets)
2x2 B/G/N 2.4 Ghz Wifi
Antenna
Reset Switch
Heatsink
