Einleitung
This is a complete teardown of the Dell Quietkey SK-8000 Keyboard.
Was du brauchst
Flip the keyboard over to expose 8 screws.
Use a Phillips screwdriver to unscrew and remove each screw.
Lift the keyboard upward from the bottom.
Use a Phillips screwdriver to remove the remaining ten screws on the aluminum plate.
Carefully lift each part out. Each part should lift out very easily after the screws are removed.
