Dieser Teardown ist keine Reparaturanleitung. Um dein Media Player Accessory zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. There are 4x 2.5mm Phillips screws holding the casing together.
    • There are 4x 2.5mm Phillips screws holding the casing together.
    • Unscrew all four screws, and lift the back cover off.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. You now have full access to all the wiring to the speakers.
    • You now have full access to all the wiring to the speakers.
    • If you need to remove the speakers, there is a little bit of glue holding them in place. You can lift them out with your finger or flat headed screw driver.
  4. This concludes the teardown of the Deloitte PL-4238 Pocket Mini-Speaker
    • This concludes the teardown of the Deloitte PL-4238 Pocket Mini-Speaker
ee460
146 Reputation
1 Anleitung geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 565
