Zum Hauptinhalt wechseln
Dieser Teardown ist keine Reparaturanleitung. Um dein Dewalt Impact driver DCF840 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Dewalt Impact driver DCF840 Teardown, Complete tool and battery: Schritt 1, Bild 1 von 2 Dewalt Impact driver DCF840 Teardown, Complete tool and battery: Schritt 1, Bild 2 von 2
    • This guide covers the complete tool and battery.
  2. Dewalt Impact driver DCF840 Teardown, Opening the tool: Schritt 2, Bild 1 von 1
    • Remove the 8 screws holding the two halves together.
  3. Dewalt Impact driver DCF840 Teardown, Internal mechanism: Schritt 3, Bild 1 von 2 Dewalt Impact driver DCF840 Teardown, Internal mechanism: Schritt 3, Bild 2 von 2
    • Battery Contacts
    • Potted Circuit
    • Brushless Motor
    • Impact Gearbox
  4. Dewalt Impact driver DCF840 Teardown, Gearbox removed: Schritt 4, Bild 1 von 1
    • With the Gearbox removed we are left with the motor on one side and the light ring on the other.
  5. Dewalt Impact driver DCF840 Teardown, Trigger mechanism: Schritt 5, Bild 1 von 3 Dewalt Impact driver DCF840 Teardown, Trigger mechanism: Schritt 5, Bild 2 von 3 Dewalt Impact driver DCF840 Teardown, Trigger mechanism: Schritt 5, Bild 3 von 3
    • Neutral: Trigger Locked
    • Forward
    • Reverse
    • When selector is neutral this tab keeps the trigger from being depressed
  6. Dewalt Impact driver DCF840 Teardown, Splitting the gearbox/impact section: Schritt 6, Bild 1 von 1
    • Gear box fits into housing as a press fit with two clips. Releasing the two clips allows the gear box to be freed from its housing.
  7. Dewalt Impact driver DCF840 Teardown, Gearbox / Impact section: Schritt 7, Bild 1 von 3 Dewalt Impact driver DCF840 Teardown, Gearbox / Impact section: Schritt 7, Bild 2 von 3 Dewalt Impact driver DCF840 Teardown, Gearbox / Impact section: Schritt 7, Bild 3 von 3
    • Planetary gear set: reduce motor speed and increase torque
    • Splines to gear box case
    • Internal teeth for planetary gear set
    • Spring (hard to see) for impact function: base spins and strikes output drive labeled with blue arrow in last picture
  8. Dewalt Impact driver DCF840 Teardown, Battery: Schritt 8, Bild 1 von 1
    • 20V battery at full charge
    • Nominally around 18.5V
  9. Dewalt Impact driver DCF840 Teardown, Splitting battery case: Schritt 9, Bild 1 von 1
    • Remove four screws to open battery
    • Spring for latch to lock battery into tool
  10. Dewalt Impact driver DCF840 Teardown, Battery details: Schritt 10, Bild 1 von 2 Dewalt Impact driver DCF840 Teardown, Battery details: Schritt 10, Bild 2 von 2
    • 5 cells nominally 3.7V in series.
    • 0V (GND)
    • 12V (likely for LED light ring)
    • 3.7V (not connected to tool)
    • 18.5V
    • 18.5V (main output)
Wieli
2.141 Reputation
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 20
Letzte 30 Tage: 46
Insgesamt: 1,217
