Einleitung
Dewalt 1/4" Impact driver and battery teardown.
Battery Contacts
Potted Circuit
Brushless Motor
Impact Gearbox
With the Gearbox removed we are left with the motor on one side and the light ring on the other.
Neutral: Trigger Locked
Forward
Reverse
When selector is neutral this tab keeps the trigger from being depressed
Gear box fits into housing as a press fit with two clips. Releasing the two clips allows the gear box to be freed from its housing.
Planetary gear set: reduce motor speed and increase torque
Splines to gear box case
Internal teeth for planetary gear set
Spring (hard to see) for impact function: base spins and strikes output drive labeled with blue arrow in last picture
Remove four screws to open battery
Spring for latch to lock battery into tool
5 cells nominally 3.7V in series.
0V (GND)
12V (likely for LED light ring)
3.7V (not connected to tool)
18.5V
18.5V (main output)
