Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Dual USB Connector zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. MSI Dual USB Port Bracket Teardown, MSI Dual USB Port Bracket Teardown: Schritt 1, Bild 1 von 1
    • This part of the bracket consists of the circuit board enclosed in a plastic housing, which we will tear down in the next step.
    • These connectors plug into the USB headers on the motherboard.
  2. MSI Dual USB Port Bracket Teardown: Schritt 2, Bild 1 von 2 MSI Dual USB Port Bracket Teardown: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Phillips #1 Screwdriver
    $5.49
    Kaufen
    • Use a Phillips #1 screwdriver to remove the four screws from the white casing and the two screws from the metal bracket.
    • On the bottom of the circuit board, the pins that hold its components can cut skin.
    • The two USB 2.0 ports.
    • The four LED lights, which light up depending on the activity of the USB ports.
  3. MSI Dual USB Port Bracket Teardown: Schritt 3, Bild 1 von 1
    • Raise the three connectors from the case and it's out!
    • The connectors highlighted in red lead to the wires that connect the bracket to the motherboard.
    • The two USB ports.
    • The LED activity lights.
samhnri
415 Reputation
2 Anleitungen geschrieben
Ein Kommentar
Why does it need its owe usb header just for the LED's.
Rick Acker - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 32
Letzte 30 Tage: 52
Insgesamt: 7,816
