Was du brauchst
Begin by removing the screws in the back of the controller.
Remove the top layer PCB. The PCB must be popped out of place and then angled in such a way that the trigger buttons at the top of the controller slide out of their slots.
Remove the second layer PCB. This simply pops out of place.
Flip over the second layer PCB. Remove the battery from its holder.
Unscrew the two screws holding the light assembly together. Once the screws are undone, the parts of the assembly can be pulled out.
6 Kommentare
Thanks this was so helpful because every time I do this I break it like literally break the plastic
Do you know where I can get broken PS4 controllers?
it doesn’t come out like that. upon opening the chassis, everything is stuck to the top part of the controller, not the bottom part.
This video on how to open a ps4 controller should help you too : https://youtu.be/9Chgw4sRTzs
