Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Easter Egg zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Easter Egg Teardown, Easter Egg Teardown: Schritt 1, Bild 1 von 1
    • So let's find out what's inside this DELICIOUS-looking Easter egg.
  2. Easter Egg Teardown: Schritt 2, Bild 1 von 1
    • First step - cut into the egg.
    • I wonder what kinds of things I'll find inside? Leprechauns? Little bunnies? The true meaning of Easter? Only time will tell.
  3. Easter Egg Teardown: Schritt 3, Bild 1 von 1
    • The innards reveal a yellowy substance. Not sure what it is, but let's dig into it some more and see if we can find out.
  4. Easter Egg Teardown: Schritt 4, Bild 1 von 1
    • Another cut is made, more yellow is found.
    • Surprisingly, no processors have so far been found. No bunnies for that matter, either.
  5. Easter Egg Teardown: Schritt 5, Bild 1 von 1
    • Two halves exposed... But what's the yellow stuff? Only one way to find out.
    • Current bill of materials:
    • Yellow mystery stuff inside
    • Pink outer layer
    • Blue swirls
    • Yellow dots
    • Red Swirls
    • Green swirls
  6. Easter Egg Teardown: Schritt 6, Bild 1 von 1
    • A formal analysis found that the yellow inner filling was, in fact, yellow cake.
    • Conclusion: Easter eggs rock!
3 Kommentare
You have a low tolerance for fainting.
Miroslav Djuric -
"This teardown is not a repair guide. To repair your Easter Egg, use our service manual" That's great. But how do I repair my pink Easter egg?
Michael - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 5,922
