Einleitung
We are going to tear down the emachine model C2881. You will only need a philips head screwdriver for this teardown.
Was du brauchst
First, loosen but do not remove the two thumb screws at the back on the left side.
Next, slide the back panel towards the back of the unit.
Then set the panel aside.
Turn the unit on its side
Then remove the screw securing the hard drive bay in place.
Disconnect the hard drive power cable, and data cable.
And remove the hard drive bay
Remove the 2 phillips head screws on the hard drive bay.
Then push the hard drive up and then pull it out
Push the clips back on the 2 LED´S and the power switch to remove each.
And then remove the front panel.
Remove the single screw securing the audio box.
Then rotate it 90 degrees down and pull it forward
Remove the two screws on the audio box. Then pull it out and set the case aside.
Now remove the 2 screws from the DVD player. Disconnect the cables and remove it.
Turn the computer back on its side
Remove the cables for the card reader, and the audio box and remove all of the above.
Disconnect the DVD drive cables, and the hard drive cables and set them aside.
Remove the four screws securing the back fan. Disconnect the cable
Pull the fan out of the inside of the case
Remove the six screws from the motherboard, one in each corner and two in the middle in between these
Grasp the motherboard by the side that would face the front of the computer, and pull it towards the front, and then up.
2 Kommentare
This workaround is not ESD conform.
You have a high risk of damaging the electronic components.
For more Information see here:
for german: https://de.wikipedia.org/wiki/Elektrosta...
for english: https://en.wikipedia.org/wiki/Electrosta...
Before Attempting to Do this Please get a ESD are antistatic mat to work on, if not then you will damage components in the system, when in doubt ask someone in the profession the right way of going about it.
