Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Projector zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Epson EB-575 Projector Teardown, Initial Images: Schritt 1, Bild 1 von 2 Epson EB-575 Projector Teardown, Initial Images: Schritt 1, Bild 2 von 2
    • I grabbed this projector from work as it had been replaced as it had coloured marks over the screen making it difficult to use in a classroom.
    • General consensus from the internet is that either the polarisers have got dust on them, or they've got too hot and it's burnt the coating off them.
    • Important Note though: After I've done this repair, it's even worse. I'll explain on the steps where mistakes were made...
  2. Epson EB-575 Projector Teardown, User Removable Parts: Schritt 2, Bild 1 von 3 Epson EB-575 Projector Teardown, User Removable Parts: Schritt 2, Bild 2 von 3 Epson EB-575 Projector Teardown, User Removable Parts: Schritt 2, Bild 3 von 3
    • Remove the filter and the filter door. The door you can take off by flexing the plastic as marked.
    • Remove the bulb cover by taking out the captive screw to get the cover off.
    • Remove the Bulb by taking out the two captive screws and pulling it upwards to get it out.
  3. Epson EB-575 Projector Teardown, PSU Cover: Schritt 3, Bild 1 von 3 Epson EB-575 Projector Teardown, PSU Cover: Schritt 3, Bild 2 von 3 Epson EB-575 Projector Teardown, PSU Cover: Schritt 3, Bild 3 von 3
    • This will get you into the Power Supply - Even if it's unplugged, there could be charged capacitors in here! You can skip this step to continue with the guide.
    • Remove Two Back screws - These are 3x6mm Black Machine Screws
    • Remove the 6 - 3x11mm Plastic Tapping Screws
    • If you want to clean the fan, there's 2 - 30mm Plastic Tapping screws holding it in.
  4. Epson EB-575 Projector Teardown, Top Casing: Schritt 4, Bild 1 von 3 Epson EB-575 Projector Teardown, Top Casing: Schritt 4, Bild 2 von 3 Epson EB-575 Projector Teardown, Top Casing: Schritt 4, Bild 3 von 3
    • Remove 5 - 3x11mm Plastic Tapping Screws from the back
    • Remove 7 - 3x11mm Plastic Tapping Screws from the top
    • Not Pictured - There's one extra screw in the air filter intake to remove.
  5. Epson EB-575 Projector Teardown, Top Case 2: Schritt 5, Bild 1 von 2 Epson EB-575 Projector Teardown, Top Case 2: Schritt 5, Bild 2 von 2
    • There are 4 cables connecting the top and bottom halves.
    • Once the 4 cables are disconnected you can remove the top case
  6. Epson EB-575 Projector Teardown, Top Case Parts: Schritt 6, Bild 1 von 3 Epson EB-575 Projector Teardown, Top Case Parts: Schritt 6, Bild 2 von 3 Epson EB-575 Projector Teardown, Top Case Parts: Schritt 6, Bild 3 von 3
    • This is the EB-575Wie Version, so it has interactivity and education features.
    • This is the Control Board with the buttons. Note the education version doesn't have buttons, but there's a PCB there still with no buttons soldered on.
    • This is the IR Remote Sensor
    • The other two arrows are IR Blasters for the interactivity and one to detect if something is infront of the lens (a safety feature)
    • The education version has an orange plate that sits ontop of where the buttons would be.
  7. Epson EB-575 Projector Teardown, Interactive Camera Module: Schritt 7, Bild 1 von 2 Epson EB-575 Projector Teardown, Interactive Camera Module: Schritt 7, Bild 2 von 2
    • You need to remove the camera module to get the main board out.
    • 3 Screws - 2x8mm Plastic Tapping
    • 2 Cables to disconnect, the third is held down by a piece of kapton tape (it was connected to the top case)
  8. Epson EB-575 Projector Teardown, Speaker (Optional): Schritt 8, Bild 1 von 1
    • You don't have to remove the speaker to get to the rest of it
    • Unscrew the 3 screws holding the speaker in - 2x8mm Plastic Tapping Screws
    • Undo the screw holding the USB Cable down (it also connects to the speaker) - 2x10mm Plastic Tapping with a Washer
    • Unplug the Speaker and remove
  9. Epson EB-575 Projector Teardown, Mainboard 1: Schritt 9, Bild 1 von 2 Epson EB-575 Projector Teardown, Mainboard 1: Schritt 9, Bild 2 von 2
    • This is all the wiring that goes into the mainboard - I've IDed most of them.
    • While you're here - remove the WLAN Grounding Screw (2x6mm Wide Head machine screw), the Weird little metal bit held in by the same type of screw and the big grounding one (2x8mm Plastic Tapping Screw)
  10. Epson EB-575 Projector Teardown, Mainboard Part 2: Schritt 10, Bild 1 von 1
    • This side panel is way easier to just slide out with the mainboard - so it's best to just unscrew it now so it doesn't hamper later efforts!
    • Remove the 2 screws from near the IEC connector - 2x10mm (or may be 2x8mm - I got these mixed up first time I pulled it apart so I'm not sure! either fits)
    • Remove 1 screw from near the VGA port - 3x6mm Silver Coloured
  11. Epson EB-575 Projector Teardown, Mainboard Part 3: Schritt 11, Bild 1 von 2 Epson EB-575 Projector Teardown, Mainboard Part 3: Schritt 11, Bild 2 von 2
    • Remove 7 Screws from the mainboard - 2x6mm Wide Head Machine Screws
    • Don't lift up the mainboard just yet! See next step.
  12. Epson EB-575 Projector Teardown, Mainboard Part 4: Schritt 12, Bild 1 von 3 Epson EB-575 Projector Teardown, Mainboard Part 4: Schritt 12, Bild 2 von 3 Epson EB-575 Projector Teardown, Mainboard Part 4: Schritt 12, Bild 3 von 3
    • There's a connector underneath the mainboard marked with the arrow
    • Use a spudger to gently lift up as close as you can to the connector to pry it loose. It shouldn't require too much force.
    • This is the top
    • This is the bottom
  13. Epson EB-575 Projector Teardown, Second Mainboard: Schritt 13, Bild 1 von 1
    • This is the board that talks to the LCD panels
    • Flick up the lever (Black part of the connector) on the Red/Green/Blue ribbon cables and gently slide them out.
  14. Epson EB-575 Projector Teardown, Second Mainboard Part 2: Schritt 14, Bild 1 von 3 Epson EB-575 Projector Teardown, Second Mainboard Part 2: Schritt 14, Bild 2 von 3 Epson EB-575 Projector Teardown, Second Mainboard Part 2: Schritt 14, Bild 3 von 3
    • Remove the 3 3x7mm Wide Head Plastic Tapping Screws from the top
    • Remove the one 6x2mm Wide Head Machine Screw from near the lens
    • From the back remove the two marked screws. The Blue marked one is 2x6mm Wide Head Machine Screw. The Purple one is 2x8mm Plastic Tapping Screw
    • Carefully Lift the second mainboard up and out
  15. Epson EB-575 Projector Teardown, Lamp Cover Piece: Schritt 15, Bild 1 von 1
    • Remove the two screws holding the lamp cover in place and pull it off. 2x8mm Plastic Threaded Screw
    • Take note of how the cables from the fan are wrapped through it - this just keeps them out of the way when it's assembled.
  16. Epson EB-575 Projector Teardown, Lamp Fan: Schritt 16, Bild 1 von 1
    • I *think* this step is optional and you can still continue without removing this piece. I took it out to give it a clean anyway.
    • Remove the one 2x8mm Plastic Tapped Screw
    • Take note of how the wires are threaded through the side of the fan
  17. Epson EB-575 Projector Teardown, Main Light Path Assembly: Schritt 17, Bild 1 von 2 Epson EB-575 Projector Teardown, Main Light Path Assembly: Schritt 17, Bild 2 von 2
    • Not sure what to call this whole piece, it's the path the light takes to get there, through a load of lenses.
    • Undo 4 marked screws - 3x11mm Plastic Tapping
    • Undo little screw holding an earthing plate near the curved lens - 2x8mm Plastic Tapping Screw
    • Lift the whole light path up, take note of the focusing slider, you can carefully maneuver it out past it without having to remove it
  18. Epson EB-575 Projector Teardown, Breaking Point.: Schritt 18, Bild 1 von 1
    • FROM HERE ON. YOU WILL VERY LIKELY BREAK YOUR PROJECTOR.
    • Touching anything beyond this point will very likely put one of the lenses out of alignment and you'll get the three colours separating.
    • See the image! The Red has separated from the other colours.
  19. Epson EB-575 Projector Teardown, Light Path and Lens Separation: Schritt 19, Bild 1 von 2 Epson EB-575 Projector Teardown, Light Path and Lens Separation: Schritt 19, Bild 2 von 2
    • See Warning - this is where you'll put it out of alignment! This is usually done in the factory with specialised equipment!
    • Remove the 2 Screws from the Top and 2 from the Bottom holding the Light Prism from the main lens
    • Be super careful when you separate these, if you hit any of the lenses you might permanantly damage it.
  20. Epson EB-575 Projector Teardown, Light Splitter: Schritt 20, Bild 1 von 2 Epson EB-575 Projector Teardown, Light Splitter: Schritt 20, Bild 2 von 2
    • I'm just making up words now... This is the part just after the bulb where it goes through a bunch of mirrors.
    • You can open this part up while the light path assembly is still in the projector.
    • Remove the 6 Screws - 2x10mm Plastic Tapping
    • Carefully lift up the top - there's a lens attached to the top piece (Blue Arrow) - don't scratch it on your way out!
    • The lenses in here are just sitting in place, with the top cover removed they will fall out if you tip it over!
    • Take note of the orientation of the lenses - take a photo before you touch anything and note the little marks on the top of some of the lenses (or maybe put a little dot of marker on the top?)
    • Some of the lenses are very easily scratched, so much that even using a cotton tip with isopropyl will scratch it! Be careful!
  21. Epson EB-575 Projector Teardown, The Prism - Detaching from Lens: Schritt 21, Bild 1 von 1
    • Here's another warning: Taking off any of these pieces WILL put it out of alignment and ruin your day - there's a reason this is a "teardown" and not a "repair guide"!
    • I forgot to get a photo of this part - once you've split off the other part from this, the grey metal piece pictured has 3 screws holding it on.
    • You can probably skip this part and leave it attached as it's easier to work with when it's still attached.
  22. Epson EB-575 Projector Teardown, Inspecting LCDs and Polarisers: Schritt 22, Bild 1 von 3 Epson EB-575 Projector Teardown, Inspecting LCDs and Polarisers: Schritt 22, Bild 2 von 3 Epson EB-575 Projector Teardown, Inspecting LCDs and Polarisers: Schritt 22, Bild 3 von 3
    • This is where I made one of my big mistakes. Unscrewing the tiny LCD Panels here will very likely put them out of alignment. They have to sit *exactly* where they are.
    • The other mistake I made was thinking I could clean the Polariser - The polarising layer is so delicate that I ended up just making it worse.
    • Remove the 4 Screws - 1x7mm Machine Thread
    • The second pic (Blue Arrow) is one I haven't touched yet. It shows where the Polariser has been scratched all the way up. This is either due to heat, or dust from the fans running up the polariser and damaging it on its way past.
    • The third pic (Red Arrow) I tried to clean with a cotton bud - Note the tiny scratch marks. It didn't have any effect on the pre-existing scratch marks.
  23. Epson EB-575 Projector Teardown, More Damage: Schritt 23, Bild 1 von 3 Epson EB-575 Projector Teardown, More Damage: Schritt 23, Bild 2 von 3 Epson EB-575 Projector Teardown, More Damage: Schritt 23, Bild 3 von 3
    • Here are some more photos of the damage to the polarisers. 2 of the 3 had severe lines up it like the images show. One was sort of OK.
    • My best guess is that this damage is caused by particles of dust being blown up across the polariser, eventually digging into and damaging the surface
    • The polariser is glued in as part of it being aligned in the factory. In terms of getting a replacement you would likely have to get all 3 LCDs + Polarisers pre assembled and calibrated to replace this part.
    • To reassemble, follow the steps in reverse!
    • Make sure you don't get any of the wires stuck under the mainboard when you put it back, or you'll have to take it back out again...
duk242
671 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 22
Letzte 30 Tage: 108
Insgesamt: 1,365
