Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Space Heater zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Essential Home HC-409 Teardown, Removed protective grill: Schritt 1, Bild 1 von 3 Essential Home HC-409 Teardown, Removed protective grill: Schritt 1, Bild 2 von 3 Essential Home HC-409 Teardown, Removed protective grill: Schritt 1, Bild 3 von 3
    • Remove the grill from corner to corner.
  2. Essential Home HC-409 Teardown, Unscrewed the four screws in the front of the heater: Schritt 2, Bild 1 von 2 Essential Home HC-409 Teardown, Unscrewed the four screws in the front of the heater: Schritt 2, Bild 2 von 2
    • Carefully remove the screws and place them aside.
  3. Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: Schritt 3, Bild 1 von 3 Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: Schritt 3, Bild 2 von 3 Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: Schritt 3, Bild 3 von 3
    • As seen in the pictures, set the screwdriver on the edge of the cover and pry it out.
  4. Essential Home HC-409 Teardown, Remove safety sticker: Schritt 4, Bild 1 von 2 Essential Home HC-409 Teardown, Remove safety sticker: Schritt 4, Bild 2 von 2
    • Remove sticker in order to open the plastic casing of the heater.
  5. Essential Home HC-409 Teardown, Pry the product in half: Schritt 5, Bild 1 von 2 Essential Home HC-409 Teardown, Pry the product in half: Schritt 5, Bild 2 von 2
    • Slowly and carefully pry the plastic casing.
  6. Essential Home HC-409 Teardown, Remove the switch: Schritt 6, Bild 1 von 2 Essential Home HC-409 Teardown, Remove the switch: Schritt 6, Bild 2 von 2
    • Apply pressure onto the sides of the switch while pushing it outwards.
  7. Essential Home HC-409 Teardown, Remove fan: Schritt 7, Bild 1 von 3 Essential Home HC-409 Teardown, Remove fan: Schritt 7, Bild 2 von 3 Essential Home HC-409 Teardown, Remove fan: Schritt 7, Bild 3 von 3
    • Unscrew the four screws located in the rear of the device. Remove the fan.
Garland Poon
126 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-8, Forte Spring 2012 Mitglied von Cal Poly, Team 14-8, Forte Spring 2012
CPSU-FORTE-S12S14G8
5 Mitglieder
17 Anleitungen geschrieben
Ein Kommentar
I keep having problems with that little part that looks like a pen cap - white plastic. Is it a connector ou a fuse?
Cristina S - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 1,452
