Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Seagate Expansion zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Expansion Teardown, Open the cover: Schritt 1, Bild 1 von 1
    • Using a flat head screwdriver or plastic tool
  2. Expansion Teardown: Schritt 2, Bild 1 von 1
    • Remove the cover
  3. Expansion Teardown: Schritt 3, Bild 1 von 1
    • Remove the drive from the case
  4. Expansion Teardown: Schritt 4, Bild 1 von 1
    • Peel back the shielding
  5. Expansion Teardown: Schritt 5, Bild 1 von 1
    • Remove the Screw with the #02 screw driver
  6. Expansion Teardown: Schritt 6, Bild 1 von 2 Expansion Teardown: Schritt 6, Bild 2 von 2
    • Separate the adapter form the sata port
Dan
4.261 Reputation
9 Anleitungen geschrieben
2 Kommentare
Hello,
I’d like to know if it’s possible to swap in another bigger NAS drive, as I keep my hard drive connected and it might be more durable.
Thank you !
Léana Jiang - Antwort
This does appear to be a semi-destructive method. In the picture under step 2, you can see the series of plastic brackets on the cover are snapped. See my pictures here
I had difficulty finding a spot to pry up from. There are 4 lips around the cover that should make it easier. See pics.
Derick Roy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 18
Letzte 30 Tage: 70
Insgesamt: 4,108
