Was du brauchst
The First Alert Smoke and Carbon Monoxide Alarm. There when you need it, also there when you don't need it and the batteries are low.
You're going to want to get a flat head screwdriver and pry open the clip on the inside to get to the inner part of the alarm.
Now what you should do is pop a small screwdriver into the rivet hole to unlock the battery holder.
Now with the the battery back area being popped out you can safely take out the ringer and the mother board of the smoke detector.
