Einleitung
In this teardown we will reveal the internals of this wonderful device, and see what is driving the realistic graphics, LEDs and 120+ sound effects
Was du brauchst
The table has 4 different play regions: Puppy's home, the market, the zoo and the farm
It also has the phone. Designed to call Puppy and friends.
All 4 legs removed
Each leg has a giant clip, that holds it in place. There is a neat tab to detach it from the table (see pictures)
"Laugh and Learn" is powered by 3 AA batteries
Depending on usage and type of the battery they deliver between 3 to 24 months of fun
The battery compartment has a gasket to protect the batteries from water (or other liquids) - very thoughtful of a typical user
After unscrewing 16 screws we can finally lift the bottom side
The on/off switch wire connector
We love modular design!
The internal side of the main board features:
60mm fan assembly with a single heat pipe and a tiny radiator
Authenticity label
Mini PCIe slot for wireless communication
DDR3 RAM slot, to buffer the audio effects
On the front side there is a tiny battery, that is probably used to back-up language settings
After removing the heatsink-and-fan assembly, the CPU is revealed
Intel i3-4005U CPU, featuring 2 cores (4 threads) running at 1.7 GHz and integrated HD4400 graphics, delivering the realistic experience of moving and talking animals and providing fast response for every button pressed on the device
The CPU is soldered down to the board, so there are no possible upgrades here
The wireless is powered by Qualcomm Atheros QCWB335 2.4GHz SB 1x1 Wi-Fi + BT 4.0
This is a standard model used for Laugh and Learn. For privacy resons there are no cameras on this phone. Major specs:
Android 6 (Marshmallow)
3.5" e-paper display. Our team was surprised by the quality - it really looks like a paper sticker!
2 buttons: home and back
Snapdragon 600 series chipset with 3G modem
The device is firmly built and easy to disassemble/repair. The only drawback is soldered down CPU
If we were asked about repairability score - the answer is 17
Thanks for reading this teardown!
12 Kommentare
Do you think you folks will be doing a Teardown for the rev. 2 logicboard? The Xeon’s cooling system looks like it’s permanently sealed shut (non-refillable) and I can’t figure out how to remove the GPS antennae
Do you think it world be possible to pop the piano keys off to clean them underneath? My 1/red button is sticky and wears the batteries out really quickly
Yes, it is possible. Switch the toy OFF. You need a long phillips screwdriver to reach all the 16 screws on the bottom. Disconnect the power wire when you lift the plastic - see photo in Step 4. Then carefully unscrew the little green board (see Step 5, on the right) and you’ll be able to remove and clean the buttons. Placing the buttons back might be a bit tricky. Good luck!
That was actually the reason why I took it apart - my kid was drooling on the piano and half of the keys stopped working :)
Forest -
