Was du brauchst
Use your iFixit Pro Tech Knife to slice and pry the different colored front and rear cases apart, as shown
Use your knife to slice off the bottom edge of the sticker found here on the rear of the board
Use a spudger to gently pry the display away from the logic board
Pry softly in each corner of the display, under the black frame
Seems to be it. The display doesn't appear to be separable from the logic board, sadly, making repairability completely out of the question.
2 Kommentare
The display can be separated from the logic board, just pull it free from the logic board connector.
My fitbit zip came apart at the seams. I decided to go ahead and clean the screen off since it was coming apart already and the screen looked dusty. Any ideas on how to put it back together? I goes back together and when I hold it everything functions, but I can't get it to stay together. Silicone? Glue? Any suggestions?
