Zum Hauptinhalt wechseln
FlySky FS-TH9X Teardown Battery Harness
  1. FlySky FS-TH9X Teardown Battery Harness, Battery Harness: Schritt 1, Bild 1 von 1
    • Locate the battery pack on the back of the device all the way at the bottom.
    • Link for the replacement part, Battery Holder
  2. FlySky FS-TH9X Teardown Battery Harness: Schritt 2, Bild 1 von 1
    • Once you located the battery pack, carefully push on the pack and down at the same time to open the back plate.
  3. FlySky FS-TH9X Teardown Battery Harness: Schritt 3, Bild 1 von 1
    • After the back plate is open, the harness battery is accessible.
  4. FlySky FS-TH9X Teardown Battery Harness: Schritt 4, Bild 1 von 2 FlySky FS-TH9X Teardown Battery Harness: Schritt 4, Bild 2 von 2
    • Locate the plug for the battery harness in order to pull it out carefully from where it is plugged.
Abschluss
Jonathan Sanchez
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 117
