Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Franklin MWD-460A zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Franklin MWD-460A Teardown, Fully Assembled: Schritt 1, Bild 1 von 2 Franklin MWD-460A Teardown, Fully Assembled: Schritt 1, Bild 2 von 2
    • Here is the fully assembled Franklin MWD-460A Electronic Dictionary.
  2. Franklin MWD-460A Teardown, Battery Compartment: Schritt 2, Bild 1 von 3 Franklin MWD-460A Teardown, Battery Compartment: Schritt 2, Bild 2 von 3 Franklin MWD-460A Teardown, Battery Compartment: Schritt 2, Bild 3 von 3
    • On the back of the case, locate the battery compartment, its cover, two grooves, and the tab (which locks the cover in place).
    • Release the cover by pulling down on the tab with a fingernail.
    • While holding the tab down, insert the opening tool into one of the grooves and gently pry the cover off.
  3. Franklin MWD-460A Teardown, Separating the Panels Part 1: Schritt 3, Bild 1 von 3 Franklin MWD-460A Teardown, Separating the Panels Part 1: Schritt 3, Bild 2 von 3 Franklin MWD-460A Teardown, Separating the Panels Part 1: Schritt 3, Bild 3 von 3
    • Locate the battery grooves.
    • Remove the batteries by inserting the prying tool into the grooves (sliding it underneath the batteries).
    • Locate the one screw inside the battery compartment, loosen it, and remove it.
  4. Franklin MWD-460A Teardown, Separating the Panels Part 2: Schritt 4, Bild 1 von 3 Franklin MWD-460A Teardown, Separating the Panels Part 2: Schritt 4, Bild 2 von 3 Franklin MWD-460A Teardown, Separating the Panels Part 2: Schritt 4, Bild 3 von 3
    • Locate the six tabs holding the two panels together along the sides.
    • Insert the prying tool into each of the six grooves and gently separate each tab from its insert on the other panel.
    • Finally, separate the panels from one another.
  5. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: Schritt 5, Bild 1 von 3 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: Schritt 5, Bild 2 von 3 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: Schritt 5, Bild 3 von 3
    • Locate the three screws holding the upper circuit board in place.
    • Loosen and remove the three screws.
    • The screw in the top right corner is also holding a tab in place so remember where it goes.
  6. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1 Continued: Schritt 6, Bild 1 von 1
    • Gently lift the upper circuit board to locate the up/down keypad and remove it.
    • Be careful when moving the upper circuit board as it's attached to the LCD screen and the lower circuit board.
  7. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 2: Schritt 7, Bild 1 von 1
    • Locate the eight screws holding the lower circuit board in place.
    • Gently pull up on the tape to expose the eighth screw.
    • Loosen and remove the eight screws along with their washers.
  8. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: Schritt 8, Bild 1 von 2 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: Schritt 8, Bild 2 von 2
    • Gently lift the two circuit boards (along with the attached LCD screen) away from their case.
    • Now peel the lower keypad from its case.
  9. Franklin MWD-460A Teardown, Full View of Disassembly: Schritt 9, Bild 1 von 1
    • Here is a full view of the disassembled Franklin MWD-460A Electronic Dictionary.
Chris L
1.498 Reputation
3 Anleitungen geschrieben
Ein Kommentar
How can I fix the screen? The letters are so faded. :(
Paola Paniagua - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 1,156
