Zum Hauptinhalt wechseln
Was du brauchst
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein Galaxy Note10 Plus zu reparieren, verwende unsere Fehlerbehebungsseite.
    Fazit
    • Equally-sized Phillips fasteners means you only need to bring one driver for repairs.
    • Many components are modular and independently replaceable, but no more headphone jack means double duty for the USB-C port.
    • Every repair starts with painstakingly un-gluing the fragile glass rear cover.
    • Replacing the glued-down battery is tougher than ever, especially with board interconnect cables to work around.
    • All-too-common display repairs require either a complete teardown or replacing half the phone.
    Reparierbarkeits-Index
    3
    Reparierbarkeit 3 von 10
    (10 ist am einfachsten zu reparieren)
10 Kommentare zur Anleitung
Samsung note s10+ fix
kamran.abbas10i - Antwort Teilen
i drop my Samsung Note 10+ and broke the display how can i replace it
Hussain Shiyan - Antwort Teilen
Sorry but the camera lens is apart of the actual rear glass.
ducky draws - Teilen
Please add how to replace the rear camera lense onle without having to take the back glass off.
Fawaz Tariq - Antwort Teilen
What are you guys return policy because i received the wrong screen. Instead of the Galaxy S10 + screen i needed my Galaxy Note 10+ one. I haven’t taken the other screen out the wrapper yet.
William Rozier - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 22
Letzte 30 Tage: 117
Insgesamt: 31,889
