Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Galaxy S23 Plus zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Galaxy S23+ Teardown, Remove the SIM Tray: Schritt 1, Bild 1 von 2 Galaxy S23+ Teardown, Remove the SIM Tray: Schritt 1, Bild 2 von 2
    • Using a SIM card eject tool remove the SIM holder and the SIM if present.
  2. Galaxy S23+ Teardown, Remove the rear glass: Schritt 2, Bild 1 von 2 Galaxy S23+ Teardown, Remove the rear glass: Schritt 2, Bild 2 von 2
    • Using an opening pick and a suction handle, cut the underlying adhesive and remove the rear glass.
  3. Galaxy S23+ Teardown: Schritt 3, Bild 1 von 1
    • Remove the 20 #00 Phillips screws.
  4. Galaxy S23+ Teardown, Remove wireless charging: Schritt 4, Bild 1 von 1
    • Unplug the two connectors connecting the wireless charging to the motherboard and remove it.
  5. Galaxy S23+ Teardown, Remove the speaker: Schritt 5, Bild 1 von 1
    • Disconnect the 5 connectors.
    • Remove the speaker.
  6. Galaxy S23+ Teardown, Unplug the front camera.: Schritt 6, Bild 1 von 1
    • Unplug the connector of the front camera.
    • REMOVE THE FRONT CAMERA ONLY IF NEEDED BECAUSE IT'S GLUED TO THE SCREEN!
  7. Galaxy S23+ Teardown, Remove the Motherboard: Schritt 7, Bild 1 von 3 Galaxy S23+ Teardown, Remove the Motherboard: Schritt 7, Bild 2 von 3 Galaxy S23+ Teardown, Remove the Motherboard: Schritt 7, Bild 3 von 3
    • Using an opening pick pull up the motherboard.
    • 12 MP Ultrawide camera.
    • 50 MP wide camera with OIS.
    • 10 MP telephoto lens camera with OIS.
    • Under this there's the RAM with the CPU.
    • A secondary microphone and the flash light.
  8. Galaxy S23+ Teardown, Remove the Charging Board: Schritt 8, Bild 1 von 2 Galaxy S23+ Teardown, Remove the Charging Board: Schritt 8, Bild 2 von 2
    • Use an opening pick to remove the speaker assembly.
    • Unplug the three connectors.
    • Unscrew the three Phillips #00 screws that secure the charging board and remove it.
  9. Galaxy S23+ Teardown, Remove the battery: Schritt 9, Bild 1 von 2 Galaxy S23+ Teardown, Remove the battery: Schritt 9, Bild 2 von 2
    • Using the tab provided, remove the battery.
Andrea Alfani
7.777 Reputation
5 Anleitungen geschrieben
Kid fixers Mitglied von Kid fixers
Community
172 Mitglieder
229 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 37
Letzte 30 Tage: 173
Insgesamt: 2,995
