Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Game Drive for Xbox zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Game Drive for Xbox Teardown, Open the Cover: Schritt 1, Bild 1 von 1
    • Using a Pry tool, remove the cover
    • This could break the plastic pins that keep the enclosure sealed. Nothing tape can't fix.
  2. Game Drive for Xbox Teardown, Remove the Cover: Schritt 2, Bild 1 von 1
    • Take the cover off the drive
    • Lifting from the end without the USB port. Remove the drive from the case.
  3. Game Drive for Xbox Teardown, Remove the Shielding: Schritt 3, Bild 1 von 2 Game Drive for Xbox Teardown, Remove the Shielding: Schritt 3, Bild 2 von 2
    • Carefully peel away the shielding
  4. Game Drive for Xbox Teardown, Remove the USB Adapter: Schritt 4, Bild 1 von 2 Game Drive for Xbox Teardown, Remove the USB Adapter: Schritt 4, Bild 2 von 2
    • With careful pressure slowly pull the adapter off the drive.
    • Keep the adapter, it is Sata to USB 3.2 Gen 1, they have value
    • Don't pull from the end, you will likely break the adapter
Dan
4.261 Reputation
9 Anleitungen geschrieben
2 Kommentare
Good teardown Dan, A very enjoyable experence indeed
Cameron - Antwort
ok, but after I pull the adapter off the drive, what next? How can I conect with laptop? I need another cable? What king of cable?
Anushka Dunyasha - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 50
Insgesamt: 2,578
