Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein GameSir T4 Pro zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. GameSir T4 Pro Teardown, Remove Screws: Schritt 1, Bild 1 von 1
    • Remove the four Philips screws circles by the red on the back on your controller. Make sure to separate the two lengths of screws. Then use the spudger to pop the clips that go around the edges of the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. GameSir T4 Pro Teardown, Removing the back shell: Schritt 2, Bild 1 von 2 GameSir T4 Pro Teardown, Removing the back shell: Schritt 2, Bild 2 von 2
    • Remove the back shell making sure not to rip the cable connecting the USB-C port to the motherboard.
    Frag FixBot
  3. GameSir T4 Pro Teardown, Disconnecting the USB port.: Schritt 3, Bild 1 von 1
    • Taking a flat tip screwdriver or your fingers, disconnect the USB connector circled in red.
    Frag FixBot
  4. GameSir T4 Pro Teardown, Disconnecting the battery: Schritt 4, Bild 1 von 3 GameSir T4 Pro Teardown, Disconnecting the battery: Schritt 4, Bild 2 von 3 GameSir T4 Pro Teardown, Disconnecting the battery: Schritt 4, Bild 3 von 3
    • Remove the battery from the motherboard. They used an adhesive material so you might need to pull hard. Disconnect the battery connector and you can remove the battery.
    Frag FixBot
  5. GameSir T4 Pro Teardown, Disconnecting the haptic motors: Schritt 5, Bild 1 von 3 GameSir T4 Pro Teardown, Disconnecting the haptic motors: Schritt 5, Bild 2 von 3 GameSir T4 Pro Teardown, Disconnecting the haptic motors: Schritt 5, Bild 3 von 3
    • There are two connectors labeled JP3 and JP4 that connect the haptic motors to the motherboard. (Circled in red) Disconnect them and if required you can now replace them.
    Frag FixBot
  6. GameSir T4 Pro Teardown, Removing the triggers: Schritt 6, Bild 1 von 3 GameSir T4 Pro Teardown, Removing the triggers: Schritt 6, Bild 2 von 3 GameSir T4 Pro Teardown, Removing the triggers: Schritt 6, Bild 3 von 3
    • Remove the ribbon cable connecting the triggers to the motherboard. Then, take out the screws and you can remove the trigger setup.
    Frag FixBot
  7. GameSir T4 Pro Teardown, Removing the motherboard: Schritt 7, Bild 1 von 2 GameSir T4 Pro Teardown, Removing the motherboard: Schritt 7, Bild 2 von 2
    • There are three screws holding the motherboard in place: two long ones and a short one. After removing them you can remove the motherboard.
    Frag FixBot
  8. GameSir T4 Pro Teardown, Removing the rest of the front panel: Schritt 8, Bild 1 von 3 GameSir T4 Pro Teardown, Removing the rest of the front panel: Schritt 8, Bild 2 von 3 GameSir T4 Pro Teardown, Removing the rest of the front panel: Schritt 8, Bild 3 von 3
    • Now to completely remove the buttons. (Bumpers, ABYX, and D-Pad) Take the front panel and remove the rest of the button just by pulling them out. They’re very easy to take out.
    Frag FixBot
  9. GameSir T4 Pro Teardown, Removing the joysticks: Schritt 9, Bild 1 von 3 GameSir T4 Pro Teardown, Removing the joysticks: Schritt 9, Bild 2 von 3 GameSir T4 Pro Teardown, Removing the joysticks: Schritt 9, Bild 3 von 3
    • Take your motherboard. Just pull on the joysticks and they should come right off.
    Frag FixBot
  10. GameSir T4 Pro Teardown, Removing the D-Pad membrane: Schritt 10, Bild 1 von 2 GameSir T4 Pro Teardown, Removing the D-Pad membrane: Schritt 10, Bild 2 von 2
    • Pull the membrane buttons off of the motherboard.
    Frag FixBot
  11. GameSir T4 Pro Teardown, Congrats!: Schritt 11, Bild 1 von 1
    • Congratulations! You have finished take apart your controller.
    Frag FixBot
Reid Quigley
193 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 20
Letzte 30 Tage: 103
Insgesamt: 675
