Einleitung
The Giiker Super Slide is a game console based on the game klotski. Opening it up is fairly easy, if you manage to get the adhesive sticker off first try. If you fail, this quickly becomes a time consuming endeavor. There are no available spare parts for the console and all modules are soldered to the main board. That being said, it only uses one screw type and one can easily replace the two AA batteries.
Was du brauchst
Start by opening up the battery compartment and removing the two AAA batteries
Remove the two bottom feet by inserting your jimmy in the edge and prying up or prying with a fingernail
Carefully pull up the speaker out of its holder using one of the four notches to get a finger under and push or carefully prying with a spudger
Remove the final two Phillips P1 screws holding down the main board
Pull up the main board carefully and set to the side
Pushing the screen in (from the viewing side) it can easily be removed. Pay note to the orientation in the image
