Was du brauchst
The tools you need are something to pry the frame open and two screw drivers one philip and one security torx
Then unscrew the 7 screws that are around the frame of the phone and don't forget the one screw thats in the middle
Then your going to take the battery outbid gently pulling upward on the wires that is connected to the white piece of plastic
then you going to take the the strip on the left hand side of the phone and pull it out with you fingers
then you take out the strip that is on the right side of the strip u just took out. (Use fingers)
Then you then you pick up the top phone chip and go to the bottom of it to take out the black strip which is the last one.
then take the bottom rectangle chip and take it out with the top square chip keep the black wire on the chips cause its hard to put back on
