Einleitung
This is a basic teardown of the HTC Rezound showing the various components.
Was du brauchst
Remove rear cover using little notch located at bottom of phone
Remove (6) Torx T7 screws
You may have to remove VOID sticker from one of the screws
Use opener tool to carefully pry cover off
Speaker is located inside back cover
Main Camera
Headphone jack
Vibration motor
Carefully unplug board
Carefully remove camera cover, slowly peeling off tape to reuse
Remove and unplug vibration motor
Remove (2) Phillips heads screws (one is shown, the other is on the left lower side)
Disconnect two cables from logic board to screen. Be very careful not to break our bend too badly.
Main camera connection & front camera
Using pick or pry tool, slowly remove screen from frame. Tape and adhesive is holding it on so work slowly and use heat gun if needed.
For the most part, this teardown is pretty straightforward with the headphone jack fused to main board. The display looks to be fused to the screen so replacement of either means replacement of both.
2 Kommentare
If there's anything I can add to help make this more clear cut and easy to follow let me know as this is my first attempt at a guide.
My rezound glass is cracked . It still operates fine but I would like to replace the glass. I ordered a glass from Amazon but it has a connection tail that I don't understand how to install?
