Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Hamilton Beach "Keep Warm" Toaster 22811 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Hamilton Beach "Keep Warm" Toaster 22811 Teardown, Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 1, Bild 1 von 1
    • Unplug toaster from wall.
    • Do not take apart a toaster that is plugged in.
    • If toaster has been used, lay down paper towels or work outside to avoid making a mess.
    Frag FixBot
    Kommentar hinzufügen
  2. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 2, Bild 1 von 1
    • Remove crumb tray from bottom of toaster.
    Frag FixBot
  3. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 3, Bild 1 von 1
    • Remove these 7 screws from bottom of toaster.
    Frag FixBot
  4. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 4, Bild 1 von 1
    • Remove bread lifter/toast booster by prying it off. The plastic piece snaps over the metal part during assembly. Use a flat-blade screw driver from the side to widen the gap in the plastic clip while pulling the plastic handle out. Done right the handle can later be reassembled securely.
    Frag FixBot
  5. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 5, Bild 1 von 1
    • Disconnect the two circuits by unplugging the wires shown. This can be done by pressing the lever on the crimps. Then the shell can be pulled off from the rest of the toaster.
    Frag FixBot
  6. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 6, Bild 1 von 1
    • Remove these 2 screws.
    Frag FixBot
  7. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 7, Bild 1 von 1
    • Remove this screw.
    Frag FixBot
  8. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 8, Bild 1 von 2 Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 8, Bild 2 von 2
    • Remove these 4 screws.
    Frag FixBot
  9. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 9, Bild 1 von 1
    • Pull apart toaster components. If power cable needs to be removed or adjusted, unscrew the screws circled.
    Frag FixBot
  10. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: Schritt 10, Bild 1 von 1
    • If the circuit for the buttons and shade selector needs to be removed, unscrew these 4 screws.
    Frag FixBot
Cal Poly, Team S18-G1, Livingston Spring 2018 Mitglied von Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 38
Insgesamt: 3,626
