Was du brauchst
Remove holding pin on outer part of fan
Pull apart front frame from back frame
Remove screws connecting the motor housing to the downrod
Detach housing from downrod
Note: Oscillation Control will no longer function
Remove Oscillation Control pin
Remove back screw
Remove Motor Casing
Remove the four screws connecting the stator to the rotor. The top two are displayed.
Detach the stator from the rotor.
Note: the fan will no longer operate.
