Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Speziell für diesen Teardown benötigte Werkzeuge
Einleitung
This guide will show you how to teardown the handle to access the power button and motherboard.
Dieser Teardown ist keine Reparaturanleitung. Um dein Hoover LiNX zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Remove the single 15mm Phillips #1 screw from the handle.
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Remove the handle by pulling it up.
    • Remove the handle by pulling it up.
  3. Remove two 15mm Phillips #1 screws from the handle.
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Use a plastic opening tool to carefully pry the black cover off of the handle. Use a plastic opening tool to carefully pry the black cover off of the handle.
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Remove five 15mm Phillips #1 black screws from the handle. Remove five 15mm Phillips #1 black screws from the handle.
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Remove the silver plastic cover using the plastic opening tool. Remove the silver plastic cover using the plastic opening tool.
    • Remove the silver plastic cover using the plastic opening tool.
Mark Nelson
404 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S7-G4, Passmore Spring 2018 Mitglied von USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 7
Letzten 30 Tage: 37
Insgesamt: 1,487
