Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Hori Pad Mini Controller zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Hori Pad Mini Controller Teardown, Hori Pad Mini Controller Teardown: Schritt 1, Bild 1 von 1
    • Unscrew the 6 screws from the back of the controller
    Frag FixBot
  2. Hori Pad Mini Controller Teardown: Schritt 2, Bild 1 von 1
    • Remove the back panel. It is not attached by anything.
    • Behold the innards of the controller.
    Frag FixBot
  3. Hori Pad Mini Controller Teardown: Schritt 3, Bild 1 von 1
    • Remove two more screws to disconnect the top green board from the bottom green board.
    Frag FixBot
  4. Hori Pad Mini Controller Teardown: Schritt 4, Bild 1 von 1
    • Notice the top and bottom boards are still connected by a soldered cable.
    • Notice the joysticks look kinda soldered on, too.
    Frag FixBot
  5. Hori Pad Mini Controller Teardown: Schritt 5, Bild 1 von 1
    • Realize you're not going to repair your finicky left joystick today.
    • Reverse all previous steps and screw it back together.
    Frag FixBot
Miles
136 Reputation
1 Anleitung geschrieben
2 Kommentare zur Anleitung
creí que mostrarias como arreglarlo
lalo diaz - Antwort Teilen
I thought I was going to fix it, but it got scary. That is why I posted it as a "teardown" instead of a "repair guide" :(
Miles - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 45
Insgesamt: 662
