Einleitung
With Huawei pushing the frontiers of phone photography, we’ve decided to peek into the P30 Pro. By “peek,” we of course mean pull it completely apart. The P-Series appears to favor some flavor of newfangled flat camera, fluffed up with some AI-driven functionality. Let’s bring it into focus with a teardown.
Don’t lose sight of more exciting news and teardowns: follow us on Twitter, Instagram, and Facebook, or check out our newsletter.
Was du brauchst
Let's put the Huawei P30 Pro into perspective with a glance at the specs:
6.47" OLED display with FHD+ (2340 × 1080) resolution
8-core Huawei Kirin 980 Processor with dual neural-network processing units and Mali-G76 MP10 GPU
6 GB RAM and 128 GB onboard storage (configurable to 8 GB RAM and up to 512 GB storage)
Leica "quad" rear camera with 40 MP wide-angle (ƒ/1.6 with OIS) + 20 MP ultra-wide angle (ƒ/2.2) + 8 MP telephoto (ƒ/3.4 with OIS) + Huawei time-of-flight module—plus, a 32 MP selfie cam (ƒ/2.0)
A new earpiece speaker technology called "Acoustic Display Technology," plus an in-display fingerprint sensor
USB-C charging port (but no headphone jack)
IP68 water/dust-resistance rating
We pull out yesteryear's P20 Pro and put it next to Huawei's latest camera prodigy for some quick comparisons:
The P30 Pro (left/bottom) is 3 mm taller, 0.61 mm thicker, and a little less wide (0.5 mm) than its predecessor.
Despite the home button and earpiece speaker grille vanishing behind the screen, the P30 Pro has grown taller.
The power and volume buttons are still where they were last year.
Along the bottom edge of the phone we see the USB-C port remains, while the four microphone holes mirroring the speaker holes have been cut down to one to make room for the SIM card slot.
Wasn’t paying attention and i put the sim eject tool in the hole in the top right. Have i damaged my device? What is that hole for?
No worries. That’s a hole for the top microphone. And you did not damage that either since it is installed at an angle like the micrphone on the bottom (step 9). Everything should still work fine.
Puse por error la llave de explulcio. En el orificio del micrófono.. Quiero saber si rompí algo internamente
No se preocupe, colocar la llave SIM en el orificio del micrófono no dañará nada.
I hope X-ray picture for whole body would be showed if possible.
In diesem Schritt verwendetes Werkzeug:iSclack$24.99
As we begin our teardown, we notice an extremely tight gap between the frame and the back glass, barely noticeable to the naked eye.
With a little heat, the iSclack, and an opening pick, we manage our way through the back cover adhesive.
Of course, the back cover is made of glass to
increase the crackability rating of the devicemake wireless charging possible.
In diesem Schritt verwendetes Werkzeug:Mako Driver Kit - 64 Precision Bits$39.95
We equip ourselves with the Precision Bit Driver and a Phillips bit from our Mako Driver Set, which is (spoiler alert) the only bit we need until the end of this teardown. For that, we're pleased.
Next out is the wireless charging coil attached to the motherboard cover, which also carries some antennas and a strange orange flex cable to bridge two contacts—what for, we're not sure.
This charging coil not only charges the phone, but also works in reverse to charge your mouse, electrical razor, or toothbrush—no kidding.
It seems that for 2019, reverse charging is becoming standard equipment on flagship phones.
With the phone now fully open, we head straight for the cameras. First out is the new periscope-style camera module that is said to make up to 50x zoom possible.
But wait—it seems this module isn't used between 1x-5x zoom, coming into play beyond 5x zoom only.
The P30 Pro has five cameras in total. Starting at top left: a 20 MP ultra-wide-angle, a 40 MP wide-angle with the Time-of-Flight camera next to it, the 8 MP telephoto (for up to 50x zoom), and of course at top right is the front-facing camera with an impressive 32 MP.
There is a shielding clip over the connector for the top back camera connector, it seems the planned removal procedure is to slide it towards the bottom of phone - freeing it from the top mounting thingy.
Before the next person stumbles over that and lifts the pad like me ^^'
If you lift the pad for that top mounting thingy: some super glue should be fine, according to the schematics I found, the pad isn't connected to anything and the spring contact right next to it seems to be GND - so as long as the other mounting thingy isn't a signal or power connection (which wouldn't make sense), it shouldn't be too bad if the newly glued-on mounting thingy touches that spring contact.
Will try to remember reporting back if that works out in the end - but waiting for replacement parts right now.
These are tear downs, not repair guides. You shouldn’t use these as a step-by-step on taking the device apart.
With the camera tour concluded, let's zoom and enhance this motherboard.
This compact piece of circuitry comes in multiple stacks. Besides having (most likely) multi-layered PCBs, this motherboard is actually two PCBs stacked on top of each other. All hail to the third dimension!
For further insight, we peel off the shields and seek out some chips:
SK hynix H9HKNNNFBMAU LPDDR4X—with the Huawei Kirin 980 layered underneath
Micron MTFC128GAOANAM-WT 128 GB flash storage
HiSilicon Hi6405 audio codec
HiSilicon Hi6363 RF transceiver
Skyworks SKY78191-11 front end module for WCDMA/LTE
Qorvo QM77031 front end module
HiSilicon Hi6H02T and Hi6H01T low noise amplifier/RF switch modules
Remember that missing earpiece speaker grille on the front of this phone? That's thanks to Huawei's "Acoustic Display Technology" speaker, which works like a vibration speaker (a.k.a. structure-borne driver).
The driving part of this module consists of a coil with a magnet in the middle. It is coupled with the part that vibrates the screen, which is glued to the back of the display.
Don't confuse it with the conventional vibration motor for alerts, which is mounted on the metal frame next to it.
On our way to the fingerprint sensor, we fish out the USB-C port, attached to a long interconnect cable.
If you opt to charge wirelessly, the wear-and-tear on this port should be greatly reduced—but when it does fail, it's nice to see that it comes out separately from the daughterboard and SIM card reader.
We're all in favor of more major component modularity (or MMCM, as no one calls it). This makes for greatly expedited repairs compared with, say, the soldered ports on the new Galaxy S10 line.
While we're here, we extract the traditional (non-display-based) loudspeaker module.
We finally reach the fingerprint sensor, mounted quite close to the bottom edge of the phone. What is the maximum thumb length here for comfortable unlocking?
This fingerprint sensor is the same Goodix GM185 optical scanner as seen in the OnePlus 6T, the Xiaomi Mi 9, and the Vivo Nex S.
The battery comes with these handy pull tabs, previously seen in the Mate 20 Pro.
While the tabs labelled "1" and "2" are somewhat useless (don't mistake them for adhesive pull tabs), number 3 helps us lever the energy cell out of the case.
A board must be packed in battery pack. It is possible to be seen by just peel off the cover film near the terminal.
Moving on to the screen, we find the second half of the glass-vibrating earpiece speaker module stuck to the back of the display as we fight through the adhesive.
Similar to the back cover, the gap between the frame and the display is virtually non-existent—and the slightly-curved edges of the display don't help, either. We're pretty sure this display is done for after the heat, cutting, and prying it's endured.
The strong adhesive strings between the frame and the display fight us like Spider-Man trying to reassemble a boat.
Having finished with the P30 Pro we focus in on the important stuff:
A tightly-glued-shut device with the barest sliver of a gap for entry
An inside crammed with nifty optical tech like a periscope camera and an in-display fingerprint sensor
A plus-sized battery with some pull tabs for grappling with the glue
And a tall screen with the earpiece speaker glued to its back.
Taking everything into account, it is time to zoom in on the score.
- A single Phillips driver is all we need to handle the screws.
- Most components are modular and can be replaced independently—except for one half of the earpiece speaker.
- Battery replacement is possible, if you're willing to fight through the glue.
- Heavily glued-down glass both front and back means greater risk of breakage, and makes repairs difficult to start.
- Screen repairs require a lot of disassembly while battling tough adhesive (back, battery and screen).
Fazit
Reparierbarkeits-Index
(10 ist am einfachsten zu reparieren)
37 Kommentare
Tnx for disassembly explanation. What is under PCB stack?
Is there any chance you will do a overview of the front internals for a wallpaper? I along with other people would be thrilled to have it :)
Orange flex looks like grounding flex. It would be nice to see what is other side of that part.
I accidentally poked the sim tool in the microphone instead of the sim tray. It still works, but i’m worried i may have compromised the water resistance… Does anybody have an idea wether or not I did?
No worries, neither the microphone nor the rubber sealing can be damaged by inserting a SIM tool in the microphone hole.
Great jobs!!!
Battery dimensions?
I installed a T-Max Huawei P30 Pro liquid screen protector. I never installed a liquid screen protector before. The kit seemed quite decent. After succesfully installing it, it says to rub off the excess glue with an alcohol wipe which I did. Had some extra glue on the edge of my phone left. The problem is that I noticed some black rubbery thing coming off as well. I think it's the adhesive of my phone. I had to cut it off with my scissors. Now it looks like this: https://imgur.com/49I3sNE
What's the chance that I ruined my P30 Pro's waterproofness?
Hi, kinda curious how so much alcohol got to the back to losen the adhesive there. This probably won’t affect the water/dust resistance in normal every day usage. According to Huawei’s footnote* to the IP68 rating I’d suggest to not submerge it anyway and avoid under water photography ;)
*HUAWEI P30 Pro is rated IP68 for splash, water, and dust resistance under IEC standard 60529 and was tested under controlled laboratory conditions. Splash, water, and dust resistance are not permanent conditions and resistance may decrease over time with normal use. Do not attempt to charge a wet HUAWEI P30 Pro. Warranty does not cover liquid damage.
Hi
Like the comment of the person before me I am interested particularly in the antennas used. Do you have any more information from when you did the breakdown? I have been told by Huawei that a 4x4 MIMO is used but they couldn’t give me anymore information, manufacturer? part number specifics? Is the GPS antenna separate? If so what is it and where is it physically situated? This has been puzzling me for awhile now would really love anything you can add
Yes, there is a vapor chamber between the display and the frame. See updated last picture of step 12, the vertical copper element.
I hear some rattle sound when shake my p30 pro. Comes near camera, top half of back.
Camera and everything works fine, is this normal?
Is that screen construction is waterproof enough? My p30 pro is soak on 20cm water in 5 minutes before I know it that is phone is not waterproof anymore (since I bought it second hand.). I do first Aid for water damage phone using rice, Silica. The phone is normal. However After 3 days the screen phone is going glitch and greenish. I’ve done with disassembly phone. I need to know if there any moisture left in display amoled itself.
New batteries should already have those pull tabs pre-installed. If you want to fix your current battery you can use regular double-sided adhesive tape or those iPhone adhesive strips.
What is in charge for wifi and Bluetooth? Is there a chip or antenna?
my “movement sensor” is broken after my phone felt.. My compass, accelometer and gyroscope seem not working.. Are these all related? Where are they located? on the motherboard or can they be replaced? Thank you very much!
Is there any way you can fix a non displaying huawei p30 pro?
Very useful. Great job! I need to know what i need to check if the device is showing -32C degrees and constantly pop up a message that the temp is low and might damage the phone and could switch off to prevent it.
I changed the display /new one was with frame/ and i had to move some pats to the new housing. Everything went ok despite the fact i damaged the orange cable from Step 4.
Could this be the problem or i should look somewhere else?
I had the exact problem. Did u find fix for that? Mine is only around -4°C but still, unable to charge..thx
Jurko -
The microphone on my p30 pro isn't work, was wondering if the microphone is one the same part as the sim card board?
The microphone is the part I circled on this image.
Thank you soo much!
I replaced the screen of my p30 pro but when i receive a call i hear the caller very weak.is it necessary to glue the speaker to the screen?is that the problem?
Did the new screen come with the counterpart for the structure-borne driver already installed (it’s the part marked L2a 931 in this picture. If not you need to transfer and glue it firmly into place on the new display.
Also, make sure there is no debris between this part and the actual structure-borne driver that could affect the sound ( the driver is the part in the bottom of the same picture).
Dear ifixit Team,
After switching to a new display, my wi-fi connection is a little weaker than before, but especially the bluetooth range has decreased very much, only half a meter guarantees a fluent music transmission. Do you know what antenna or cable might be the reason for this and what should I purchase to try to fix it? Would appreciate any hint!
Hey Guys, I have a P30 Pro that is not doing any loud speaker sound (so no audible ring sound, music, youtube sound, call on loud speaker), I tried replacing the loudspeaker module but it didn’t work (I will try ordering another loudspeaker to try again, don’t know if the first was working), also tried ordering the daughterboard (with the CHIP) as it looks like it has some kind of filter for the audio right under the conector under the armor (or am I wrong?) but the board came without the armor and anything soldered there.
Any advice on what to test, the audio signal come by the big flat cable? Maybe trying to replace it too?
Already done software reset and even downgrade using huawei software.
Don’t know what else I can try to fix it.
I need help with my Huawei p30 some have water damage i live in sweden. I need my Phone in The cort. Please can some one help me.
Very good article, thank you. I dissembled the phone and replaced the sim card reader and antenna hoping it would now read my sim again. This wasn't the fault it seems. Would it perhaps be the motherboard?
