Was du brauchst
Einführungsvideo
Remove battery. Attention: Be careful with the adhesive and the flex under the battery.
When removing the battery don't just be carefullof the flex cable underneath it. Also be very carefull of the battery, mine just exploded !
Done.
We are sorry that didn't separate the screen from mid-frame. Because we can't open a gap between them even after a long time heating and many times try. It's said there is glue but not the sticker around the screen. So if operate with force, it's at high risk to break that good screen and scratch the frame.
But you can do it freely when you have cracked the screen and need a screen replacement.
3 Kommentare
Bonjour,
La vitre de l'objectif de l'appareil photo arrière de mon P7 est complètement griffée, j'aimerais bénéficier donc de la "vitre" du vôtre. Je n'ai besoin que de la première fine couche je pense ainsi que l"outil nécessaire... Est-ce possible? Merci
Hi
Thanks for the great tutorial. I was getting very weak reception with my P7 and I disassembled my phone today and replaced the antenna flex cable but it didn't make a difference; Can you please tell me where is the antenna for gsm located in this phone?
Hola
Excelente tutorial, bastante completo y muy bien explicado.
para los que estan buscando cambiar el display solamente les agrego que no es necesario desmontar toda la placa base (tarjeta logica) con despegar la bateria y desconectar el flex es suficiente, ya lo demas con presicion y el calor adecuado pueden despegar la parte delantera.
