Einleitung
Basic disassembly of the Jolla C (mostly the same as the Intex Aqua Fish)
Was du brauchst
Remove the back cover, starting at the bottom right corner with your nail or a prying tool
Remove the battery
Remove all sim-cards
Remove the microSD-card
Remove all 14 cross-head screws
Use a prying tool to separate the middle cover from the phone, working from the bottom slowly up to the top
Watch out for the power and volume buttons, which probably fall out of the device.
Remove all cross-head screws
Remove the antenna wire from the circuit board
Pry loose the power & volume button part at the side (it is stuck to the phone with sticky tape) and pull it out
Pull out the connector for the bottom cuircuit board
Pull out the screen connector
Pry loose the connector for the proximity sensor etc
Remove the main and front camera connectors
Remove the antenna cable
Remove the speaker and vibration motor from the phone
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
