Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein LG G Watch R zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. LG G Watch R Teardown, Front and Back: Schritt 1, Bild 1 von 2 LG G Watch R Teardown, Front and Back: Schritt 1, Bild 2 von 2
    • LG G Watch R assembly.
  2. LG G Watch R Teardown, Removing the back cover: Schritt 2, Bild 1 von 2 LG G Watch R Teardown, Removing the back cover: Schritt 2, Bild 2 von 2
    • First remove the watch band using a small flat screw driver to compress the spring loaded pin.
    • Remove the four T4 torx screws (Green).
    • Carefully pry the base off using a thin flat screw driver
  3. LG G Watch R Teardown, Removing the Board: Schritt 3, Bild 1 von 2 LG G Watch R Teardown, Removing the Board: Schritt 3, Bild 2 von 2
    • Disconnect the four electrical connectors from the board
    • Orange - Battery connector
    • Blue - button and charging connector
    • Green - Backlight
    • Purple - O-LED Controller + Mic
    • Remove the three phillips screws securing the board down. Then lift the board off the base
  4. LG G Watch R Teardown, The Battery: Schritt 4, Bild 1 von 2 LG G Watch R Teardown, The Battery: Schritt 4, Bild 2 von 2
    • The battery is below the board.
    • The battery can easily be pried out using a small flat head screwdriver.
  5. LG G Watch R Teardown, Battery housing: Schritt 5, Bild 1 von 1
    • Using a small pliers and a small flat screwdriver the battery housing comes out easily.
  6. LG G Watch R Teardown, P-OLED Panel: Schritt 6, Bild 1 von 3 LG G Watch R Teardown, P-OLED Panel: Schritt 6, Bild 2 von 3 LG G Watch R Teardown, P-OLED Panel: Schritt 6, Bild 3 von 3
    • Pictures of the front and back of the 1.3" P-OLED.
    • The screen is glued in.
8 Kommentare
Is there a wifi antenna inside the LG G watch R?
Fernando Perez - Antwort
Yes, there is a WiFi antenna inside the LG G Watch R, however WiFi functionality was only recently added to the G Watch R in a more recent update via Android Wear.
Mark Fortune -
Are there differences between the UK as US G Watch R?
James Kemble - Antwort
Where could I find a battery for replacement?
Thanks in advance.
Fab - Antwort
Any tips for what to check if the touchscreen turns on but is non-responsive ?
richard - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 20,176
