Einleitung
I have tried to include as much detail as possible in this teardown. I have even inspected the chips on the mainboard! Thanks for looking, and I hope you find this useful.
Was du brauchst
Found this phone lying around, so decided to make a teardown of it!
First, remove the backplate by pushing the button at the top of the back of the phone.
The front and back of the device should separate.
Two buttons should come off after you have removed the back.
This is the rear speaker.
Both of these buttons need to be pried from the front casing to allow the mainboard to come away from the front housing.
The front speaker also has to be pried from the front housing.
The buttons on the front housing can then be pushed out through the back of the housing.
The EMI shield can be removed by unclipping the clips on the side of the device.
In the centre of the picture is the vibration module. It can be unclipped to remove it.
The LCD ribbon cable and connector are under a plastic sheet that has to be removed.
The ribbon cable can then be take out of the connector
Chip inspection time!
Mediatek ARM MT6A01AA
Samsung K5D1H12ACC-A075 NAND flash memory
Skyworks Solutions SKY77524-15
CSR 51E130A14U
