Einleitung
This guide will demonstrate how to fully disassemble the LG Optimus L9 P769
Was du brauchst
Here's what LG's L9 P769 holds hardware-wise:
Dual-core 1.0 GHz CPU
4.5 inch IPS LCD with a resolution of 540 x 960 pixels
4 GB of internal storage
5MP Primary camera and VGA front facing camera
Wi-Fi 802.11 a/b/g/n, dual-band, Wi-Fi Direct, hotspot, DLNA
Power off the device and gently lift the battery cover off to access the battery
Lift and remove the battery from the notch in the edge of the battery compartment
Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using the PH000 headtype
Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
Using a spudger or small prying tool, pry off the latches that connects the digitizer to the chassis carefully.
Carefully remove the digitizer from case by sliding out connected ribbon cable
Remove the remaining circuitry utilizing a smaller prying tool or a small flathead screwdriver
Carefully slide out circuity to remove phone display
Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
