Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein LG T310 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. LG T310 Teardown, LG T310 Teardown: Schritt 1, Bild 1 von 1
    • Slide back cover down with hand in the direction of the arrow on the cover
    • Gently remove back cover
    • Remove the battery by inserting the plastic opening tool into the groove and gently prying it out
  2. LG T310 Teardown: Schritt 2, Bild 1 von 2 LG T310 Teardown: Schritt 2, Bild 2 von 2
    • Remove all of the screws on the back of the phone using a Phillips head screw driver
    • Slide out the SIM card from the phone
  3. LG T310 Teardown: Schritt 3, Bild 1 von 1
    • Using the plastic opening tool, pry off the shell of the phone, revealing the motherboard
  4. LG T310 Teardown: Schritt 4, Bild 1 von 2 LG T310 Teardown: Schritt 4, Bild 2 von 2
    • Using the plastic opening tool, gently pry the motherboard out (while doing this be sure not to pull on the mother board as it is attached to the touch screen)
    • Starting at the top left corner of the screen (with phone face down), insert your plastic opening tool and work down the left side.
    • The screen should be loose now making it possible to remove it from the case by hand (try not to touch the actual screen, only the side or back).
    • This completes the tear down of your LG-T310 Cookie
Andrew
116 Reputation
1 Anleitung geschrieben
University of Maryland, Team 1-5, Calloway Fall 2013 Mitglied von University of Maryland, Team 1-5, Calloway Fall 2013
UMD-CALLOWAY-F13S1G5
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,417
