Was du brauchst
Disconnect the cables
Webcam module cable
Display panel cable
Service button (Factory testing)
LG Display LM270QQ2 LCD Panel
Chip ID for the logic board
Realtek RTD2799 Monitor Controller
Samsung DDR3 RAM
Texas Instruments TUSB8041 Four-Port Super-Speed USB 3.0 Hubs
Texas Instruments TPS65983B USB Type-C and Power Delivery (PD) 3.0 Controller
Genesys Logic GL3523 USB 3.1 Gen 1 Hub Controller
Intel JHL7440 Thunderbolt 3 Controller (Titan Ridge)
NTP7515D Audio Amp
Realtek ALC4020 Audio IC
NTP7515D Audio Amp
Texas Instruments LP8860AQ1 LED Driver
NXP Semiconductors LPC11U68J 32-bit Microcontroller
Webcam module with Microphone, Ambient light sensor and Camera indicator light.
Cypress Semiconductor CYUSB3064-BZXC USB SuperSpeed Camera Controller
STMicroelectronics Image Signal Processor (ISP)
Camera
Microphone
Chip ID for the LCD control board
Analogix/LG Display ANX1706 Display Controller
Separate the LCD structure inside the panel
The cable between control board and panel
7 Kommentare
Hey, do you know if the outer (glossy) panel is removable (changeable) or permanently laminated to the screen?
It is a fully laminated display module.
Excellent, thanks for this! Is it possible to replace the built in camera with a more modern one? Any thoughts in this?
I think it is impossible since the camera module is highly integrated to the main board, there are also some special pins to route the audio signals from the camera module to the audio chip on the main board.
Hi Andy,
Thanks for the tear down, With the bezel is it just clipped on and just requires the use of a spudger to get it off?
