Dieser Teardown ist keine Reparaturanleitung. Um dein LG Y90 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. After we open the back cover of the unit
    • After we open the back cover of the unit
    • this shows the mid frame and main board of the unit.
  2. Remove the back camera from the main board
    • Remove the back camera from the main board
  3. Gently remove the front camera connection from the main board. Gently remove the front camera connection from the main board.
    • Gently remove the front camera connection from the main board.
  4. Remove the LCD connection from the main board.
    • Remove the LCD connection from the main board.
  5. In this step, i used a cut of vinyl card for prying the main board.
    • In this step, i used a cut of vinyl card for prying the main board.
    • Make sure that you pry it gently
  6. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. This is the main board of LG Y90 supposed to look like.
    • This is the main board of LG Y90 supposed to look like.
  8. Remove the vibrator of the unit, you can use a pry or any soft flat and non-conducting material. Remove the vibrator of the unit, you can use a pry or any soft flat and non-conducting material.
    • Remove the vibrator of the unit, you can use a pry or any soft flat and non-conducting material.
  9. Remove the front camera with your own pry gently. The front camera should look like this.
    • Remove the front camera with your own pry gently.
    • The front camera should look like this.
  10. Remove the ear piece. Remove the ear piece.
    • Remove the ear piece.
  11. Remove the audio jack. Remove the audio jack.
    • Remove the audio jack.
  12. This are the placement of the components that you remove.
    • This are the placement of the components that you remove.
  13. The mid board. The mid board.
    • The mid board.
  14. Lastly, the back panel.
    • Lastly, the back panel.
Kriztofferson Mosqueda
217 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 287
