Was du brauchst
After we open the back cover of the unit
this shows the mid frame and main board of the unit.
In this step, i used a cut of vinyl card for prying the main board.
Make sure that you pry it gently
Remove the vibrator of the unit, you can use a pry or any soft flat and non-conducting material.
Remove the front camera with your own pry gently.
The front camera should look like this.
