Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Lenovo Chromebook Duet (ZA6F0016US) CT-X636F zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Lenovo Chromebook Duet Teardown, The Device: Schritt 1, Bild 1 von 3 Lenovo Chromebook Duet Teardown, The Device: Schritt 1, Bild 2 von 3 Lenovo Chromebook Duet Teardown, The Device: Schritt 1, Bild 3 von 3
    • As you can see, this is my own personally device that my daughter actually dropped and cracked the glass. I plan to repair it, once parts are available of course.
  2. Lenovo Chromebook Duet Teardown, The Device: Schritt 2, Bild 1 von 1
    • It's a pretty slick device and I'm really impressed by what it can do, especially for it's price
    • 1. USB-C (Gen 2)
    • 2. Power button
    • 3. Volume control
    • 4. Guide pins
    • 5. 5-point pogo pins
    • You can find the entire list of specs on Lenovos website here
  3. Lenovo Chromebook Duet Teardown, Open!: Schritt 3, Bild 1 von 3 Lenovo Chromebook Duet Teardown, Open!: Schritt 3, Bild 2 von 3 Lenovo Chromebook Duet Teardown, Open!: Schritt 3, Bild 3 von 3
    • I expected to have to heat up the screen and deal with a display adhered in. I'm super happy to announce that is not the case here!
    • The screen assembly is held in with clips! No heat, no adhesive.
  4. Lenovo Chromebook Duet Teardown, Like a Book: Schritt 4, Bild 1 von 3 Lenovo Chromebook Duet Teardown, Like a Book: Schritt 4, Bild 2 von 3 Lenovo Chromebook Duet Teardown, Like a Book: Schritt 4, Bild 3 von 3
    • Once all the clips are free, the screen opens like a book the the left.
    • The lower flex cable for the display is on the upper left.
  5. Lenovo Chromebook Duet Teardown: Schritt 5, Bild 1 von 3 Lenovo Chromebook Duet Teardown: Schritt 5, Bild 2 von 3 Lenovo Chromebook Duet Teardown: Schritt 5, Bild 3 von 3
    • Replacing a cracked screen requires you to remove the frame on the broken screen and using two way tape to attach it to the new screen.
  6. Lenovo Chromebook Duet Teardown, Remove the Display: Schritt 6, Bild 1 von 2 Lenovo Chromebook Duet Teardown, Remove the Display: Schritt 6, Bild 2 von 2
    • Just a couple Philips screws hold a bracket over the batter connector
    • Two more Philips screws hold the LCD assembly screws as well.
  7. Lenovo Chromebook Duet Teardown, Internal Overview: Schritt 7, Bild 1 von 1
    • Rear Camera
    • Front Facing Camera
    • Charging Port
  8. Lenovo Chromebook Duet Teardown, Charging Port: Schritt 8, Bild 1 von 3 Lenovo Chromebook Duet Teardown, Charging Port: Schritt 8, Bild 2 von 3 Lenovo Chromebook Duet Teardown, Charging Port: Schritt 8, Bild 3 von 3
    • The Type-C Charging port, very much modular! Thank you Lenovo!
    • The text reads 8SSP69A6 P80NHS00 03X00T1 Abxud
  9. Lenovo Chromebook Duet Teardown: Schritt 9, Bild 1 von 1
    • Full IC Identification for Charge Port Board:
    • You may need to enlarge it to view the text.
  10. Lenovo Chromebook Duet Teardown, Speakers + Antennas: Schritt 10, Bild 1 von 3 Lenovo Chromebook Duet Teardown, Speakers + Antennas: Schritt 10, Bild 2 von 3 Lenovo Chromebook Duet Teardown, Speakers + Antennas: Schritt 10, Bild 3 von 3
    • The Right antenna reads 187373-WIFI1-W-V1.0-B
    • The Left reads 187373-WIFI2-W-V1.0-B
  11. Lenovo Chromebook Duet Teardown, Cameras: Schritt 11, Bild 1 von 3 Lenovo Chromebook Duet Teardown, Cameras: Schritt 11, Bild 2 von 3 Lenovo Chromebook Duet Teardown, Cameras: Schritt 11, Bild 3 von 3
    • Rear camera reads F8V07S SUNNY I9482
    • Front facing camera reads D2V05P
  12. Lenovo Chromebook Duet Teardown, The board: Schritt 12, Bild 1 von 3 Lenovo Chromebook Duet Teardown, The board: Schritt 12, Bild 2 von 3 Lenovo Chromebook Duet Teardown, The board: Schritt 12, Bild 3 von 3
    • Front and back of board
    • also, are these test points? neat!
  13. Lenovo Chromebook Duet Teardown, Chips: Schritt 13, Bild 1 von 3 Lenovo Chromebook Duet Teardown, Chips: Schritt 13, Bild 2 von 3 Lenovo Chromebook Duet Teardown, Chips: Schritt 13, Bild 3 von 3
    • Can't find any reference to this Chip, ITE is all I can seem to read.
    • SEC 946 B620 KMDV60010A GHGF689P RAM
    • MEDIATEK ARM MT8183V 1932-ZAMAH CTPNUN82-A the CPU
  14. Lenovo Chromebook Duet Teardown, Look! More Chips: Schritt 14, Bild 1 von 3 Lenovo Chromebook Duet Teardown, Look! More Chips: Schritt 14, Bild 2 von 3 Lenovo Chromebook Duet Teardown, Look! More Chips: Schritt 14, Bild 3 von 3
    • MTK MT6370P 1945-ABSH ATFPX203 I believe this is a MediaTek WiFi chip of some type?
    • MEDIATEK MT6358W 1926-ANAH CCMJ2NPS OT1342 Some sort of power IC
    • QUALCOM ATHEROS ModelL QCNFA324 WiFi Chip
  15. Lenovo Chromebook Duet Teardown: Schritt 15, Bild 1 von 1
    • Full IC Identification for Main PCB:
    • There were many unknowns here.
  16. Lenovo Chromebook Duet Teardown, Battery: Schritt 16, Bild 1 von 2 Lenovo Chromebook Duet Teardown, Battery: Schritt 16, Bild 2 von 2
    • Looks like some little pull tabs keep the battery in. I guess we can't have everything. But I'm happy for pull tabs and not just some adhesive I'd have to dissolve and slowly pry at. I'm going to keep this part in, since this tablet still works 100%, and I will be reassembling.
    • The model reads L16D2P31 It is a 7000mAh
  17. Lenovo Chromebook Duet Teardown, 5-point pogo pins: Schritt 17, Bild 1 von 2 Lenovo Chromebook Duet Teardown, 5-point pogo pins: Schritt 17, Bild 2 von 2
    • The little pins the keyboard connects too is held by 3 little screws and looks pretty easy to replace.
  18. Lenovo Chromebook Duet Teardown, Frame: Schritt 18, Bild 1 von 2 Lenovo Chromebook Duet Teardown, Frame: Schritt 18, Bild 2 von 2
    • The power and volume buttons aren't even connected to the board, they use the little surface connectors.
  19. Lenovo Chromebook Duet Teardown, Done!: Schritt 19, Bild 1 von 1
    • While I'm not office iFixt it, I'd say, in my experience I'd give this a 8 out of 10, for repairabily.
    • On the up side, the screen is held in with clips, meaning no adhsive or heating to open the tablet, unlike what seems every other tablet I work on these days. Lets hope repalcemt parts come in the frame, not require we move the plastic frame over to the new screen. Most of the parts are modular, including the charging port and buttons.
    • Also on the upside, all the screws are the same size, which makes for easy reassembly. The speakers are also pretty easy replace.
    • on the down side, the battery is adhered in, and some parts, like the WiFi chip are soldered on. However, looking at this from a Tablet perspective, and not a PC, that's to be expected. It does look like it might be replaceable, even if it is soldered.
    • I hope to provide updates on this device once I see what replacement parts are like, as well as cost.
Jeff Caauwe
1.206 Reputation
2 Anleitungen geschrieben
JCow Repairs LLC Mitglied von JCow Repairs LLC
Business
1 Mitglied
52 Kommentare
Great teardown! Thank you very much!
Johannes - Antwort
Any idea when anyone might be selling the screen? I just cracked mine, and getting it replaced through Geek Squad would cost the same price as just buying a new one.
Chris Mc - Antwort
I couldn’t quite tell for sure from the picture, but I assume that eMMC is soldered on. Any thoughts on the feasibility of a storage update?
Rick Burdeniuk - Antwort
I don’t image we could. Android and Chrome OS is all encrypted these days, so the storage and CPU are probably tied together.
Jeff Caauwe -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 28
Letzte 30 Tage: 155
Insgesamt: 24,773
