Einleitung
How to completely disassemble your tablet.
__________Video tutorial:__________
Was du brauchst
Einführungsvideo
Unscrew the two Phillips screws under the memory card and the SIM card covers.
Use a plastic tool and remove the back cover.
Unscrew the 8x screws and remove the mother board cover.
Disconnect the battery connector.
Volume Buttons, Power Button and Vibration motor
Audio Jack Connector, Touch Screen Flex Cable connector, LCD Display Flex Cable Connector.
Wi-Fi Antenna Connector, Speaker Connector, GPS Antenna Connector.
Remove the lower speaker and the microphone.
Unstuck the Power button, Volume buttons and Vibration motor from the middle frame.
Unhook the LCD Display and the Touch screen flex cables.
2x Phillips screws securing the main board.
Remove the Logic board.
Be careful, the mother board is sticked to the front outer case.
CPU - Mediatek, MT8317ATA
Memory chip - eMMC(16GB)+LPDDR2(1GB) - KMK3U000VM-B410
Power management chip - Mediatek MT6329BA
That's all.
2 Kommentare
my mini usb track to board is damaged, can i repair it or can i know from where i can buy the PCB board for Lenovo Idea tab a1000
Thanks for this guide!
