Zum Hauptinhalt wechseln
Was du brauchst
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein Lenovo ThinkPad zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Lenovo ThinkPad X1 Carbon 6th Gen Teardown, Lenovo ThinkPad X1 Carbon 6th Gen Teardown: Schritt 1, Bild 1 von 2 Lenovo ThinkPad X1 Carbon 6th Gen Teardown, Lenovo ThinkPad X1 Carbon 6th Gen Teardown: Schritt 1, Bild 2 von 2
    • Insert wisdom here.
IT FIX
6.340 Reputation
74 Anleitungen geschrieben
8 Kommentare
computer quit - dark screen and no more life. Any ideas
nmenon - Antwort
I experienced this too (dark screen, but otherwise laptop seemed to respond just fine… like caps and numlock keys were working, beep sound at boot). Attaching an external monitor gave image (after booting into OS). Re-seating the internal eDP connector fixed my issue (apparently it was a bad connection). I hope the cable is not damaged or so…
Tim Bruylants -
I wonder if thermal pads that look like grey foam are efficient at all. Thinking to replace them with the traditional ones.
Artem Nikolaev - Antwort
Try to mesure the temp before and after it’s interesting
IT FIX -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 29
Letzte 30 Tage: 146
Insgesamt: 29,324
