Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Lenovo U41-70 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Lenovo U41-70 Teardown, Tightening Hinges, Tools+ Removing Backpanel Screws: Schritt 1, Bild 1 von 3 Lenovo U41-70 Teardown, Tightening Hinges, Tools+ Removing Backpanel Screws: Schritt 1, Bild 2 von 3 Lenovo U41-70 Teardown, Tightening Hinges, Tools+ Removing Backpanel Screws: Schritt 1, Bild 3 von 3
    • Remove 10 Phillips Screws
  2. Lenovo U41-70 Teardown, Tightening Hinges, Removing Backpanel: Schritt 2, Bild 1 von 2 Lenovo U41-70 Teardown, Tightening Hinges, Removing Backpanel: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Use Plastic Card to loosen Plastic clips
    • Carefully work your way arround
    • The whole Backpanel is held in place by plastic clips around the left, right and front
  3. Lenovo U41-70 Teardown, Tightening Hinges, Open!: Schritt 3, Bild 1 von 2 Lenovo U41-70 Teardown, Tightening Hinges, Open!: Schritt 3, Bild 2 von 2
    • Remove Backpanel beginning at the front and working your way to the back
  4. Lenovo U41-70 Teardown, Tightening Hinges, Tighten Hinges: Schritt 4, Bild 1 von 3 Lenovo U41-70 Teardown, Tightening Hinges, Tighten Hinges: Schritt 4, Bild 2 von 3 Lenovo U41-70 Teardown, Tightening Hinges, Tighten Hinges: Schritt 4, Bild 3 von 3
    • Locate Hinges at the back
  5. Lenovo U41-70 Teardown, Tightening Hinges, Tighten Hinges 2, Done!: Schritt 5, Bild 1 von 1
    • Use Pliers or Spanner to tighten
    • Righty- Tighty
    • Lefty- Loosy
    • Be careful not to tighten the bolts too strongly - you might later break the Plastic when trying to open the lid.
fixer
862 Reputation
3 Anleitungen geschrieben
2 Kommentare
I just bought this laptop last week and I was thinking of returning it because of loose hinges. Despite of awesome features, this hinge problem is a deal breaker for this model. Thank You for posting this article. This gave me a hope and thus I am keeping the laptop.
Lidiya - Antwort
Thank You, it was easy to repair. The only Problem is the strengh of These hinges - too strong, too loose….
Werner - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 24
Insgesamt: 5,802
