Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Speziell für diesen Teardown benötigte Werkzeuge
Einleitung
Demo teardown at Maker-Faire 2010
Dieser Teardown ist keine Reparaturanleitung. Um dein Linksys BEFSR41 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Top down view of the device.
    • Top down view of the device.
  2. There actually aren't any screws or notches under the rubber feet on this model. A little force is all that's needed to pull off the front blue panel. (The front is held on by a recess/notch on each side)
    • There actually aren't any screws or notches under the rubber feet on this model. A little force is all that's needed to pull off the front blue panel. (The front is held on by a recess/notch on each side)
  3. Once the front blue panel is off, the top panel slides back and then comes off easily (it's connected to the bottom panel by two plastic notches).
    • Once the front blue panel is off, the top panel slides back and then comes off easily (it's connected to the bottom panel by two plastic notches).
  4. Remove one small Philips screw from the logic board so you can remove the bottom panel.
    • Remove one small Philips screw from the logic board so you can remove the bottom panel.
  5. After removing the single screw and sliding off the bottom panel, all that is left is the main circuit board.
    • After removing the single screw and sliding off the bottom panel, all that is left is the main circuit board.
    • Main Components
    • Barrel-plug power connection / CAT5 / Reset button
    • Power Control
    • Line-drivers (allow CAT5 cables to carry data for 100m)
    • RAM (2Mb) (Stores MAC tables, etc)
    • KS8695 ARM922 (ARM Core, 5 switchboards, tcp/ip/udp packet interface)
    • RAM (1Mb )
  6. Bottom view of circuit board.
    • Bottom view of circuit board.
Ryan McLeod
454 Reputation
2 Anleitungen geschrieben
Thanks Ryan. Couldnt figure out how to get the case off until I checked here.
My BFSR41v2 teardown was identical so was able to replace the two 1000uf caps shown in step 5. The router gradually lost speed and finally quit altogether and wouldnt reset. Found the first cap had 5v AC across it and felt warm. The second cap was ok but replaced it anyway and the router is like new. BTW I was using it as a switch behind my wifi router to get more ports on my wired LAN.
Theres a good description of how to repurpose an old rouiter as a network switch on the How-to-geek site.
Cheers
Bill - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 3
Letzten 30 Tage: 8
Insgesamt: 13,987
